Display says "L8" ??? - Office Equipment & Supplies
    Sergeant:
  • 168 Answers
Are you sure L8 ?
Likely I knowed about Error 78...
Machine error 76-78 are fuser errors. 95% of the time due to a sudden power loss like during a thunderstorm. The machine turns off for a brief second then back on. When this happens the machine likes to go read the fuser's temperature without waiting for it to warm up. It reads a low temperature and gives you the code. Most brothers service modes are entered by pressing Menu,*,2,8,6,4. Has to be done in a certain time frame so it might take a try or two. Once entered the machine will beep, the lights on the display will flash and it will read MAINTENANCE. Next enter 9,9 and the machine will reboot. That should fix the issue if not and your mechanically inclined I would pull out the fuser and check for continuity across the lamps and thermal fuses.
I hope helps.
Posted on Oct 06, 2010
My sharp mx 350 shows error code L8 :1 how will i reset it?
L8-01 error should reset itself automatically after repair. This code means something wrong with power supply or power distribution. It is job for experienced engineer, all you can do is reconnect connectors of power supply harness.
Aug 15, 2016 | Sharp MX-M350 All-In-One Printer
Why does the display say L5
this a problem in 2 ways:
1) test the input voltage motor, if there are the motor need repair.
2) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram atached.
Sep 07, 2012 | Landice L8 LTD Cardio Trainer Treadmill
Landice L8 automatically turns on by itself
It is either the control board or the overlay. I would think it is probably the start button on the overlay that is stuck. The solution is to replace the overlay.
Mar 05, 2011 | Landice L8 LTD Cardio Trainer Treadmill
Am looking for a service manual for a Beckman L8-80M Ultracentrifuge. Inparticular, I need the schematics for the circuit boards
I was wondering if you ever received the board schematics you were looking for? I have an L8-70M and also need them to diagnose a problem with power outages in the display board. Apparently you can purchase the service manual from Beckman, but I was told it costs ~$600.
Sep 11, 2010 | Medical
Landice L8 has an L5 error displayed wont start up
is a speed sensor problem or the card connectors are wired specifically where the motor wires, sometimes that part is too hot and breaks the solder
Jul 19, 2010 | Landice L8 LTD Cardio Trainer Treadmill
Error code L8 on XEROX model 5305
That indicates the main board has not sensed the exposure lamps coming on. Those are solder in lamps, I believe there are 6 or 7 on the array.
Mar 01, 2010 | Xerox Office Equipment & Supplies
I have a Landice L8 and the error code L5???
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
Jul 09, 2009 | Landice L8 LTD Cardio Trainer Treadmill
No signal
hi ive got the same problem.no signal. ihavent opened mine. im not sure how to. let me know if you get it fixed, what the problem is thanks trish griffin_pat@btinternet.com
Sep 16, 2007 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
97 people viewed this question
jasbo
jasbo
