Question about Kodak Cameras
I have fully charged my batteries and my kodak easyshare c713 will turn on and then off immediately. The last time I tried it would not turn on at all. Please help I have three small children with daily photo opt needs!
    President:
  • 2,761 Answers
Your problem could be due to one or more of the causes below.
Remove the batteries and check them and the camera contacts for corrosion. Even a small buildup can prevent current from flowing to the camera. If present, wipe battery ends and camera contacts with a clean, dry cloth, then try charging/operation again. Heavy buildups, if present, will require cleaning with a fine wire brush, steel wool, or sandpaper.
If possible, also check the batteries with a voltmeter or test them in other equipment to ensure that they are in fact taking and holding a charge. Batteries more than a year old may need to be replaced. Also check the charger output if possible, and try other batteries in the camera.
If you have recently dropped the camera, you may have caused damage to the lens zoom mechanism. This will cause the camera to shut down in order to prevent more serious damage. This problem requires professional repair.
Bill B
Posted on Oct 06, 2010
Kodak easyshare c713 showing lens error 221,0,0,0. what does this mean.
KODAK C713 LENS ERROE 20E 1,0,0?
IT DID NOT RESOLVE AFTER PUTTING NEW FULL CHARGE (AA) SIZE BATTERY EVEN , WHEN I TURN ON CAM IT SHOWS ERROR 20E 1,0,0 AND SHUT DWON.
Dec 31, 2009 | Kodak EasyShare C713 Digital Camera
Camera Kodak C713 does not turn on..even on trying new batteries..It is 1 year old..
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 30, 2009 | Kodak EasyShare C713 Digital Camera
White out LCD screen
Try a manual reset. Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Oct 05, 2009 | Kodak EasyShare C713 Digital Camera
Kodak C713 dose not turn on back.
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 25, 2009 | Kodak EasyShare C713 Digital Camera
Cannot turn on my Kodak easyshare c713
Hi I had the same problem with my daughters c713. Tried several bateries found out that the camera is specific with its bateries brand. When i put in new ones from kodak itself from my sons camera a c913 the c713 turn on again. Tried a new pack local brand checked them first and voltage was ok but didn´t work again. Back in those from kodak and ok again. Tried philips also ok.
So try different brand and find out. Good luck.
Jaap Davids The Netherlands
Jun 17, 2009 | Kodak EasyShare C713 Digital Camera
Camera turns itself off immediately even though it is fully charged
are you using rechargeable batterys or cheap ones
you have to get batteries specifcly designed for digital cameras or they wont power the camera properly.. try using different batteries !!
May 22, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Camera won't stay on
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
May 11, 2009 | Kodak EasyShare Z740 Digital Camera
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
Cameras Logo
73 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
