Question about Kenwood KAC-7252 Car Audio Amplifier
Kac 7252 Was working now no red light or sound what could it be?
5 Suggested Answers
  • 32 Answers
SOURCE: my kenwood kac-7252 lights up but puts out no
check ground, most amps required that you ground straight from the batt. also check your rca jacks
Posted on Mar 06, 2009
SOURCE: help
i agree with the person who said that the ohmage is lower than the 4 ohm, but also check to see if your voltage drops lower than 10 volts it used to happen to mine and the fuse kept blowing
Posted on Aug 04, 2009
  • 24 Answers
SOURCE: i a looking to qire two 10 inch kicker comps what
check the ohms on the subs if its single 2 ohm make sure you dont bridge it avoid 1 ohm unless the amp is class d duel 2s make 4 or 1 depending on if you series on paralel them duel 4s make 2 ohms or 8 you want to make a duel 4ohm 2ohm and put one on each chanel email me for better exp.
Posted on Feb 06, 2010
  • 14 Answers
SOURCE: looking for a wiring schematic for a kenwood
Click on this link. It will give you everything you need.
http://images.kenwood.eu/files/prod/23/5/KAC-7252-7202_(EN).pdf
Posted on Feb 15, 2010
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
I a looking to qire two 10 inch kicker comps what is the best way to get sound out of this set up in a sealed box and kac 7252 amp 1000 watt
Feb 05, 2010 | Kenwood KAC-7252 Car Audio Amplifier
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
What does it mean when the power light blinks on the amp?
genrally kenwood amps are power hungry amps so after playing for a while if it doesnt get the amount of amperage to make it work it will shut down cus you car cant charge the battery long enough for the use of that amp so my idea is try a farad capacitor and see if that helps good luck .......tk
May 29, 2009 | Kenwood KAC-7252 Car Audio Amplifier
My kenwood kac-7252 lights up but puts out no sound can someone help
Mar 06, 2009 | Kenwood Excelon KAC-X521 Car Audio...
Help
If it only does it when bridged, the ohm load may be too low.
Is it blowing the fuse on the amp or the one near the battery?
Jun 15, 2008 | Kenwood KAC-7252 Car Audio Amplifier
Power of amplifier
If the KAC-7252 is to be bridged, the operation mode switch on the top of the amp is set to mono. When switched to Mono, the signal from the left channel input only is used. Bridging creates 4 times as much power so the KAC-7252 delivers 170 Watts per channel so that 340 watts total so that value 340 is multiplied by 4 and that gives you 1360 watts of power. so it will drive them.
Aug 27, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Light stays red
I do belive this amplifer has a red light when it is on... I know my Kenwood does. I suggest checking all your wireing between your amp and your speakers, check the impediance between your positive and negative terminals on your leads to the subs.
Mar 28, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Kenwood KAC-7252 Car Audio Amplifier Logo
42 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
