Question about LG 24.7 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Titanium
The control pad on the dispenser is not working
  • 262 Answers
The first thing I would do with your machine is : inspect the Main controlboard on the rear of the machine... I would look to see if the capacitors have domed. (((( Their are many capacitor on the board... But the tops should all be flat... if any are domed they are bad.))) if they are then I would replace the main control. if not then the dispensor control could be bad.
Mr Fix it Appliance
832-695-2102
Posted on Oct 06, 2010
WATER NOT DISPENSING IN DOOR
I am having the same problem. Water pad just click when pushed and ice works fine. Just wondering if you found out what the problem was and resolved it.
Jul 14, 2014 | Jenn-Air Refrigerators
We have a GE profile side by side stainless steel refrigerator. The control panel touch pad does not function.
The electronics behind the touchpad may have failed. You usually change the whole panel/pod as a single item - could be expensive and perhaps something else has failed, so it could be a waste. First check all connections to it are dry and not corroded. if they are OK Try to buy a used panel/pod on ebay, then change it
Dec 14, 2013 | Refrigerators
How to refill a pebble post it note dispenser
Please use the following steps to load the Post-It(R) Pebble-Shaped Pop-Up Note Dispenser:
1) In order to remove the lid from the dispenser you will need to twist the dispenser in half. While holding the top of the dispenser with one hand, use your other hand to support the base. You will need to twist the two part and then pull them apart to separate them.
2) Once the back is open, place one pad of Post-It(R) Pop-Up Notes into the top opening of the dispenser, feed the top sheet from the pad through the slot on the front panel. Make sure you are using Post-It(R) Pop-Up Notes and not the standard Post-It(R) Notes, as the standard notes do not have the alternating adhesive format and will not pop-up properly.
*Please note that we recommend that yo u use one pad at a time.
3) After the pad has been loaded into the dispenser, you can put the top cover over the base and twist them back into place.
Oct 25, 2012 | Office Equipment & Supplies
Water wil dispense, but unable to change to ice dispense. None of the bottoms will work, including lock and light.
It sounds like your control panel has a short, please call your Jenn-air rep for assistance. thank you.
Oct 11, 2010 | Jenn-Air JCD2389G Side by Side...
For some reason the dispenser will stop working part of the time and more recently will stick on and overflow.I pulled the cover off the inside of the door and there is ice buitl up on the insulation.
You need to thaw out the ice machine and see if it works after you thaw it out if that does not fix the problem then the control arm for the ice dispenser is bent.
Nov 22, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Dispensing unit doesn't work
could be the dispenser control board.
Sep 15, 2008 | Jenn-Air JCD2389G Side by Side...
Control pad flashing temp and all lights continuously and ice door continually cycles open and closed
With the problems it is presenting, I would say it's very likely.
However it may take a bit of detective work to find which board is defective.
Check a part suppliers link Here for price comparison so you have some ideas.
Jun 26, 2008 | Kenmore TRIO 77314 Side by Side Bottom...
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
LG 24.7 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Titanium Logo
66 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
