Question about D-Link DES-3550 (D85116) 48x10/100 Mbps Networking Switch
How to reset a dlink DES 3550 ip add loose, no more access
4 Suggested Answers
  • 17 Answers
SOURCE: DLINK SWITCH DES-1008D
It sound like your network is setup as follows;
Modem -> Switch -> pc's
Most ISP's will only lease you a single IP your network should look more like this;
Modem -> routing device -> pc's
Where routing device is an actual router or firewall that leases private addresses to your pc's and routes outbound traffic to the public address your ISP has leased you.
Do you have more than one computer plugged into this switch? Do none of them work?
Posted on May 02, 2008
SOURCE: DES-3226L A1
Log in to the switch as an administrative user (using the login command).
You can type the following command:
reset {config|system}
If you type "reset config" all of the factory default settings are restored on the switch except for the IP address, user
accounts, and the switch history log.
If you type "reset system" all of the factory default settings are restored on the switch.
If you just type "reset" by itself, the switch’s current IP address, user accounts, and switch history log are retained. All other
parameters are restored to their factory default settings.
Posted on Jul 24, 2008
  • 74 Answers
SOURCE: i want the default ip address, domain name and password
by default ip is 192.168.0.1
and username and password admin
Posted on May 11, 2010
What is the default IP address of D-Link DES-1024R for accessing from PC for switch management?
the usual ip add of a Hub or Router or Switch is either 192.168.0.1 or 192.168.1.1. to determine the Ip Add you can check it - Start - Run (for XP) - type Run in the search box and use the Run command - in the Run Box type in "CMD" - a small black box will pop up (that's the command prompt) - then type in "ipconfig" - look for the "default gateway" that's the ip add of the switch or hub or router.
Hope this helps
Jun 21, 2011 | D-Link DES 1024R Plus (DES-1024R+/5)...
My home network is such that I have a DLink Gigabit switch right behind my DSL router to dispatch network connections through the home. I already connected several devices that work without problem. One...
Check the network settings of your pc in network and sharing, adapter settings , right click local area connection and press properties, click IPv4 and look at its properties. Ensure ip and DNS are bother set to auto.
press start, type cmd right click the grey chalk board press run as administrator. Type ipconfig /release then type ipconfig /renew
also try a different port/cable if it is a gigabit switch an orange light means it is running below the speed. I.e. 10/100 if it is working correctly the lights should be green.
Apr 06, 2017 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Sir I Have DLINK DES 3526 L2 mangable switch, its earlier configured an ip which is 192.168.1.17 using this ip i access the switch yesterday and i change it to the DHCP configure but now i want to allot...
All Dlink routers has a reset button at the back. Just use a paper clip to press and hold that button hole until the router turns off itself and restarts again. Your router will then return back to defaults with 192.168.0.1 IP address.
Please let me know if this helps. Thank you for using FixYa.
Oct 08, 2010 | Computers & Internet
Does d link des 1016d provides dynamis addresses to network printers?
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
Aug 06, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
What is the default ip address for dlink 3226?
The Switch's factory default IP address is 10.90.90.90
with a subnet mask of 255.0.0.0 and a default gateway of 0.0.0.0.
Often set up by rs232 connection
See
ftp://files.dlink.com.au/products/DES-3226S/QuickInstallGuide/Generic_QIG_for_Managed_Switches_v1.03.pdf
and
http://support.dlink.com.au/Default.asp
Apr 20, 2010 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Ho to reset dlink3226 switch
Have you got a manual for the D-Link switch?
You may find the info in the manual, if you have lost the manual you can download a manual from this WEB site - Use this link :-
http://safemanuals.com/annexe_Reference%20Guide_D-LINK_DES-3226-_E.htm
Sep 17, 2009 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
DES-3226L A1
Jun 20, 2008 | D-Link DES-3226L Networking Switch
D-Link DES-3550 (D85116) 48x10/100 Mbps Networking Switch Logo
396 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
