Question about Kenwood Audio Players & Recorders
KS-505HT My system for surround sound is set up for audio thru kenwood tuner and speakers, tv speakers are not in use. Using my tv remote I can turn on tv and cable box but for sound I have to use the kenwood remote (I can also use kenwood remote to change channels and turn on tv). During a broadcast I mistakely pushed a button on the tuner remote and lost the sound. If I change the system to radio receiver I am able to get sound, if I change to tv mode I get no sound. I have a copy of the Kenwood speaker system instruction manual which covers only the installation method. You can contact me by email or phone by calling area code 702-558-0994. If there is a customer service department I can call direct please advise the phone number and contact person's name. Your assistance in this matter will be greatly appreciated.
  • 6 Answers
SOURCE: can't get audio from HD TV to run through Yamaha receiver speaker
be more specific!...how is the tv hooked up? hdmi, component, straight to the tv, or into the amp then tv?....what audio out? optical, digital? also what are you trying to view? local programming? cable/sat? dvd? your best bet is to ignore video on the amp and go straight to tv. can't help u more until i have more specifics.
Posted on Jan 23, 2009
  • 63 Answers
SOURCE: Kenwood VR-305 receiver surround speakers will not work
make sure that all input cables are in the correct positon also make sure that any inputs you are using don't have a macrovision in them that will also kill your sound due to copyright laws and stuff but main thing check all wires coming in to receiver and if you need more inputs go to walmart and get a rca splitter basicaly its a 1 in two out connection to add more cables in the input
Posted on Mar 16, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Posted on Sep 17, 2009
Testimonial: "worked like a champ!"
  • 6 Answers
SOURCE: Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Posted on Jan 10, 2010
How do I connect Samsung smart TV to a Yamaha receiver and get sound to come out of surround sound speakers?
Generally you will connect the Digital audio or optical audio cable from TV to the input of Receiver. Then using the remote control of Receiver you will program the source for digital audio or optical audio as TV. I am assuming the speakers on the receiver are already connected and working. All you do is then turn on TV and turn on Receiver and select TV on Receiver. The TV audio will play through the receiver. Make sure the TV sound is in Mute.
Aug 07, 2014 | Yamaha Audio Players & Recorders
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
I have had the Kenwood VR-407 since 2001. I also have a Mitsubishi projection TV, attached to the receiver. When watching regular cable TV (u-verse), I can not get sound from the rear speakers. I am using...
Most TV stations you watch don't send a surround sound mix so you won't get anything in the back speakers. DVDs generally all have a surround mix which is why it sends to all speakers. What you are experiencing is normal, Bob.
Jan 04, 2011 | Kenwood VR-407 Receiver
Can not get my surround sound system to work with Sharp LC-40F22E using usual audio cable, sound still comes through the tv speakers and can not find how to turn tv speakers of or tell the tv to use...
The way to turn off the tv speakers is to press the menu button scroll to the option category navigate to output select and choose variable. However just turning off the tv speakers will not cause the surround sound system to work with this television. Connecting the red and white composite audio cables to the television's OUTPUT will get you stereo sound. Some people opt to keep the tv's speakers turned on when doing this. In order to get the digital optical out to work between the television and the surround sound system you will have to be using input tv. You will have to be using the television's tuner with digital cable no cable box or with an over the air antenna. Did you make sure you connected the red and white cable to the surround sound aux or any composite input and choose the right function on it?
Dec 03, 2010 | Sharp Televison & Video
Surround sound not working with PS3..
hook your front speaker wires up to the A side and on the front of it make sure only the A speakers are playing but leave the rear speakers plugged into the B side then hit the listen mode button and you should be rocking
Apr 24, 2009 | Kenwood VR-407 Receiver
NO SOUND FROM TV THROUGH THE SOUND SYSTEM SPEAKERS
All you need to do is follow the following directions on your TV and you will be on your way listening to your great Philips TV on your great Sony Surround Sound. You do not need to buy any other cords or anything else. Its just a setting on your TV that needs to be adjusted.
By the way, I have a Sony Home Thearte System DAV-HDX275 and I've had it for almost 8 months and its sounds good with my TV and Movies. The speakers are very cheap and it doesn't give you the sound you expect. So I came accross some Boston Accustics CR65's that are not sold anymore but they did run around $700 a peice. I am upgrading the Reciever very soon to a better qualtiy Reciever. This Surround Sound System is great for a starter Surround Sound System.
  1. Press MENU on the remote control and select TV settings >
  2. Press up or down to highlight a sound setting and press right to select the setting.
  3. Press up or down to adjust the setting, and press OK to confirm the change.
  4. Press Menu to exit.
You want to pick Incredible Surround, but if that does not work try them all. The Incredible Surround should do the trick because that switches it from the TV Speakers to the Surround Sound.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Have a Great One!
Mar 13, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
No sound from surround speakers
you have it set in stereo mode change listen sound to auto this way whatever way the signal is coming thru you will hear it
Jan 09, 2009 | Kenwood VR-405 Receiver
Help With My Rear Speakers
Just clicked on sound effect on the lg tv remote it was set to 2.1 changed to 5.1 and the system came alive!!
Oct 07, 2008 | LG LHT854 Theater System
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
274 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
