Question about Linksys Wireless-N WRT150N Router
I PURCHASED A CISCO LINKSYS BROADBAND N ROUTER AND I USED THE CD THAT CAME WITH IT. AFTER 3 HOURS OF SETUP IT FINALLY WORKED. HOWEVER WHEN I TRIED TO GO ONLINE THE VERY NEXT DAY, MY COMPUTER KEPT SAYING IT WAS NOT CONNECTED TO THE INTERNET. WHAT WOULD YOU SUGGEST I DO NOW?
  • Linksys Master
  • 7,733 Answers
Linksys Support ->link.,
Posted on Oct 06, 2010
Free software download
You can download it online by using good search engine.
Jul 26, 2013 | Cisco Linksys E1000 WirelessN Broadband...
Can not get into e2000
Who is your Internet service provider?
If it is a DSL company then in some cases the router IP address may change to 192.168.0.1.
What happens when you try to open 192.168.1.1.
Does it ask you for user name and password?
Did you install router using cisco connect software?
Open cisco connect software.
go to router settings.
Click on Advanced settings.
It will open the setup page.
See Linksys E2000 router setup
Mar 05, 2012 | Cisco Linksys E2000 Advanced WirelessN...
When I try to access my cisco e1000 router on firefox or google it keeps saying that it is busy and will not connect
Are you trying to access the setup page of the router?
Did you install the Cisco connect software on your main computer?
If you have cisco connect software installed then open Cisco connect.
Go to Router settings. Click on Advanced settings. It will open the setup page of your router.
If the cisco connect is not installed then try to power cycle the router. Unplug the power to the router, wait for 30 seconds. Plug in the power cable. Wait for 30 seconds.
Now try to access the setup page.
If that is also not working then I will suggest you to reset the router and reconfigure it manually.
Watch video.
How to reset Linksys router.
Watch Video:
Linksys router setup
Feb 24, 2012 | Cisco Linksys E1000 WirelessN Broadband...
What a error 323
Are you trying to setup your router using installation CD.
Try setting up your router manually.
See Linksys router setup
Jan 14, 2012 | Linksys Wireless-G Broadband Router
My acer aspire one netbook will not connect with my new linksys e2000 router.. It was fine with my former linksys router
If your former linksys router was NOT N but rather b/g, then the problem is likely that your new router is running N and must be reconfigured to run b/g instead of n on its wireless. The acer aspire one netbook's integrated WiFi is 802.11b/g and the only way to do 802.11n is by using a plug-in USB 802.11n wireless adapter. To manually configure the router's wireless for 802.11b/g or n...
1. Connect the netbook using an ethernet utp cat5 patch cable between one of the four RJ-45 LAN ports on the router to the 10/100 ethernet RJ-45 port on the netbook's left side.
2. Start a browser like Internet Explorer and enter IP address 192.168.1.1 (default for Linksys)
3. On the login window, enter admin for username and admin for default password, then click OK
(The password may be changed if the router's setup software on its CD has been run.)
4. On the Linksys Setup page, click the Wireless tab
5. On the Linksys Wireless page, for Network Mode, click v for drop menu and click BG-Mixed
The preceding is from Chapter 3: Advanced Configuration which starts at page 16 of the 59-page Linksys E2000 user guide/manual. If you are missing this manual, it can be obtained by clicking...
http://homedownloads.cisco.com/downloads/userguide/E2000_UG_USA_V10_NC-WEB.pdf
A final note: The easiest way to setup the router is to run its setup software on the CD that comes with it. If you want to do this with the netbook (which doesn't have an internal CD drive), an external CD drive would have to be plugged into one of its USB ports.
Jan 25, 2011 | Cisco Linksys E2000 Advanced WirelessN...
I just bought my new Cisco Linksys E1000 WirelessN Broadband router, set up the brand new cat 5 wires and hooked it to my modem. My old lap top is able to see the wireless network but my alienware lap top...
if you're running windows 7 sometimes it tries to auto detect the type of network but doesn't ask for a password, when it starts to try to auto detect hit cancel and enter in the password manually.
Dec 31, 2010 | Cisco Linksys E1000 WirelessN Broadband...
How to install the cisco links E2000 advance wireless N router in the computer. i tried bt cannot install it
there are two ways of installing a linksys E-series router
>>first is the easy setup disk/ if it will not work, try to dissable the firewall of your computer
>>if still doest work, you can access the setup page of the router with the DG, 192.168.1.1
>>for cable connection always do a mac address clone
>>for DSL, change the lan IP,
>>call linksys tech support, iwill be glad to solve your problem
Dec 12, 2010 | Cisco Linksys E2000 Advanced WirelessN...
Think my router is bricked, can jtag fix this & how ?
Press the reset button on the router and hold it down for 30 second. Wait for 10 seconds. Now unplug the power to the router and plug it back in. Wait for 1 minute.
The router will be back to the factory default settings. Now run the CD that comes with the router. Install the Cisco connect software and see if that works.
If the Cisco connect software is not working then you can try to etup the router manually without the CD.
Click here for more informartion about router setup
Oct 09, 2010 | Cisco Linksys E1000 WirelessN Broadband...
How to setup linksys router
You can setup Linksys router without installation CD or software.
Connect the computer to the router and open the setup page of the router.
Change the Internet and wireless settings manually.
I will suggest you a website on How to setup Linksys wireless router.
This website may help you installing your router
May 28, 2010 | Linksys Wireless-G Broadband Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-N WRT150N Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
