Question about Philips 60PP9352 60" Rear Projection Television
60PP9352 60 in. Rear - Blue convergence issue
I have a problem with my 60PP93 5217 tv. The Blue convergence went wako and is unadjustable through the convergence menu. I've been reading about replacing the STK ic chip and some transistors. I'm not sure if I should just do the Chip, or the transistors, or both. Or maybe I should try the chip first?
Also, do you know the location of the transistors.
I would appreciate any help on the matter.
  • sergiojg May 28, 2008
    Thanks Jaime, This is really helpful.
    Do you happen to know which resistors I need to replace? I may as replace the resistors and like you said do it once.
    Thanks Jaime, So it looks like the best solution is to just do both the chip and resistors. Do you happen to know which resistors I should replace? I haven't open up the back of the set yet.
  • 2,323 Answers
Replacing only the ICs MAY solve the problem, however, many people have also had blown resistors requiring replacement. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
You do not have to replace any transistors to fix this convergence failure.
Posted on May 28, 2008
  • Jaime Hernandez May 29, 2008
    I will check the schematic diagram and let you know later about the resistors that might have to be replace if they are damage.
I have Sony KP-46WT500 Projection TV. For some time it appears convergence went bad. I see multiple images, especially at edges and corners. As many as 3 images Red, Blue and Green. I am an Electronics...
It would be great to assist you in Sony convergence issue.
As you said, for some time TV shows bad convergence in picture that shows its matter of lose/ dry solder joints in D board, specially on convergence out ICs pins that need to be re-solder.
There are 2 big black ICs mounted on aluminum heat sink on D Board of TV, below image shows D Board location in TV.
Resolder pins of these 2 ICs and also check any other dry/ cold solder joints in circuit board. I do not think of IC replacement as problem occurs some time.
Let me know if you have additional question.
Thanks.
Dec 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Convergence IC + Resistor swap = Blue light clicking noise
Good Day,
It sounds like you may have slightly diconnected a cable. Look for the large RED cable/wire that goes to the Blue tube and make sure that they are very secure. When doing this make sure the TV is off.
Good Luck, BIG IRISH.
Dec 16, 2009 | JVC AV-56WP74 56" Rear Projection...
I've a mitsubishi ws-65909 and the picture is out of synch. Went to the convergence menu and I'm unable to get the blue in line with red and green and the blue convergence grid can't seem to be realigned....
Hi my name is Roety,
I can help you with your issue ,
If you can solder you can replace the Convergence ICs
A repairman would charge about $400 to do it for you
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 06, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
Color convergence problem
If you follow the instructions on the other thread, you should be able to resolve the problem. Try the simple stuff first. Resolder the pins of the convergence ICs and see if that alone resolves the problem. Sometimes that is all it takes.
Keep us posted.
Dan
Jan 30, 2009 | Mitsubishi WS48511 48" Rear Projection...
HItachi convergence problem - blue only
Replace both of your STKs 392-110s use 180s.
Nov 27, 2008 | Hitachi 51F500 51" Rear Projection...
Red Convergence
http://schematicscom.blogspot.com/
http://homenol.blogspot.com/
Visit these sites. Convergence procedure of projection televisions are given in detail.
Mar 28, 2017 | Televison & Video
Toshiba cinema series convergence problem
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many brands of projection TVs are given in detail.
Jul 10, 2017 | Toshiba CX36F84 TV
Blue shadow
You need to replace both convergence ICs numbers STK392-570 this is an easy repair which requiresasic soldering skills. you can get replacement ICs that come with free step by step instructions with pictures so you can do the repair yourself, they also provide free on line tech support in case you have any questions . Heres the link
http://servicemanuals.vstore.ca/
May 11, 2008 | Sony KP-51HW40 51" Rear Projection...
Projection TV wil not cut on.
You should first replace the convergence IC's, both of them. Also make sure all the resistors on the convergence IC's are good and not burnt. That's probably what you smelled burning. Good Luck
Jul 11, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
