Question about Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range
I have a Stoves GDO900 gas double oven. After I have lit the grill successfully, and after the grill gets hot, the igniter begins to spark even though the gas has not gone out. All other igniters on both top and bottom ovens work fine. To make things worse, the problem is intermittant so somtimes it's fine. I suspect the problem isn't with the spark generator as the others are fine - could you suggest another cure and, if so, would it require a qualified gas engineer to sort.
  • 1314 Answers
SOURCE: stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
Posted on Mar 15, 2008
SOURCE: hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
Posted on Dec 30, 2008
  • 18 Answers
SOURCE: Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Posted on Jan 23, 2009
SOURCE: stoves gas oven 600 sdlm panache bell on the timer
Hi we found that happened and we just pressed one of the buttons and it went louder again. I think you can adjust it yourself. Its happened a few times and I always managed to change it.
Posted on Mar 17, 2009
SOURCE: Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
Posted on Apr 15, 2009
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
How can I stop the oven igniter continuing to spark after the oven has lit
This should not be a problem as the setup is it doesn't know which gas knob has been turned on, therefore the oven and grill spark to ignite either .
Hope this is helpful
PS if I had known the make and model number you can probably get a manual online.
Oct 31, 2014 | Ovens
Not sure of model and have no manual. Stoves
it sounds like your flame safe devives is gone have it checked by someone quilifed.....
Dec 30, 2009 | Kitchen Ranges
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
Oven won't stay lit
Welcome to Fixya
My name is Huum,
The igniter is bad even if you see the spark.
the igniter must first get red hot with enough amps to ignite the gas or the valve will not open or if ope it will shut off!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 01, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Hi i cant seem to get my grill or oven on can any one help
Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
hi thanks for the question so the igniter works but no gas most of the gas stoves have the same problem if the igniter works but no gas could still be the igniter the igniter must get almost white hot to ignite the gas if id does not the gas wont lite so the ather problem is igniter lights but no gas problem is with the 2 coils on the gas valve replace those thanks the appliance doc
Sep 17, 2008 | Whirlpool Kitchen Ranges
Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
60 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
