Question about LG WM-2277HW Front Load Washer
LG WM-2277HW Water overflowing from soap drawer (compartment)
I got an IE error message and was welcomed by a flooded floor. My drain pump filter was full of lint & garbage. I cleaned out the filter and tried to run the washer. After a minute or two water pores out of the soap compartment drawer.
    Champion:
  • 210 Answers
The water dispenser compartment is connected to a hose. Disconnect the hose where it attaches to the tub. You will find a gray mushroom valve, remove this completely or you can just cut back the rubber that covers the stem halve way. What is happening is the valve is getting stuck in the up postion, and causing the water to poor out the front. You should also be running a hot wash every so often to clean out the unit.
Posted on May 30, 2008
    Genius:
  • 1,028 Answers
Look for port inside top area of basket where water comes in may be plugged with same junk found in pump
Posted on May 29, 2008
WHAT DOES OE MEAN ON DISPLAY ?
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Oct 06, 2011 | LG WM-2277HW Front Load Washer
Door will not unlock and water will not drain also get an err.code oE
Correct, OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter located inside the bottom front panel for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Aug 10, 2011 | LG WM-2277HW Front Load Washer
What does oe mean
Kevin
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
Jul 23, 2011 | LG WM-2277HW Front Load Washer
LG washer WM 2277HW Wont spin LE on control panel
LG error codes:
UE: Imbalance: Load too, small too large
LG washer notes:
Problem:
An occasional LE error but always a slow or no spin.
Solution:
A Red wire going to the Hall sensor was intermittent. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. Problem was in the short wire harness that connects directly to the motor and hall sensor. Could not find the open point of the wire so added a new red wire and integrated it into the harness.
Your service manual and more LG washer notes HERE
Mar 07, 2011 | LG WM-2277HW Front Load Washer
OE error message checked drain hose for kinks drain hose is clear
OE is a drain error and is displayed when the washer is unable to drain water. As you have already checked the drain hose and it is clear so check the drain pump filter for any clogs to clean the error. If the problem is still there after cleaning then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 15, 2011 | LG WM-2277HW Front Load Washer
LE code
IE: Water level (246) was not reahed in 8 minutes
middle of L. Upside down F) Thermister out
PF: power failure momentary interuption of shocktricity
WM-2277HW service manual and more HERE
Thanks for using FixYa
Jan 07, 2011 | LG WM-2277HW Front Load Washer
It won't drain...keeps stopping and says OE
Kevin
Dec 11, 2010 | LG WM-2277HW Front Load Washer
I am getting a FE erroe on my LG WM-2277 HW Washer? What Part do I need?
Hi
Thanks for using FixYa. FE is Overflow error which means that the water is overflowing and the water level frequency is over 213. When FE error is displayed the drain pump operates to drain the water automatically. To resolve this issue you’ll have to check the water inlet valve and pressure sensor which can sense the water level in the tub, if any of this goes bad overflow occurs. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | LG WM-2277HW Front Load Washer
Soap drawer is filled with water
Our 2 year old washer just started seeing this problem. After removing the detergent dispenser drawer from the washer, cleaning it and cleaning the slot it came from we stopped seeing water retention.
May 09, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
923 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
