Question about Jenn-Air JMV8208AAS Microwave Oven
Need a replacement bulb for my Jenn-Air JMV8208AAS microwave. Plate on the bottom of the microwave says 130V/35W halogen bulb is the replacement, but we can't seem to find one. Is this right?
5 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: Jenn-Air Microwave turntable not working, microwave works
The coupler may be cracked or the motor may be weak.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Oct 22, 2007
SOURCE: Setting clock on Jenn Air M166 built in microwave
sure..push clock pad twice..set time..push stop/start
Posted on Mar 23, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Removing a built in Jenn-Air Microwave from it cabinet...
First of all, what are the symptoms? Please reply back and I'll be happy to share my thoughts.
Many parts can be accessed without removing the oven from the wall by just removing the control panel.
You need to be sure the cord is unplugged, then you remove the vent grille that runs across the top.
Then you'll see a screw holding the control panel in place. Once that screw is out, you can lift out and out carefully to separate the control panel form the chassis.
If you pull any wires off the control panel, mark and/or photograph them first to be sure you get them ALL back in the right place.
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Before you start, we have *critical* safety & disassembly info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
While they don't have their installation instructions online, the owner's manual is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: jenn air microwave jmv8208bas The light
From the service manual:
The top full-width grille is removable for service to some components, such as: humidity sensor, oven light, door removal, flame sensor, vent motor capacitor, fuse, control panel, and stirrer motor (some models).
Grille Removal
1. Disconnect power to oven.
2. Remove screws located in front on top of microwave securing grille.
3. Pull outward on the top portion of the grille releasing the tabs.
4. Reassemble in reverse order.
The oven lamp part original number is 4713−001165 but you can get it locally (generics) at hardware stores, appliance parts stores, etc. It's a common 20 watt halogen bulb.
Posted on Oct 22, 2008
Jenn air microwave model jmv820aas shut down completely, what do i do?
I'm guessing you might mean JMV8208AAS?
If so, then the service manual is at our site here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order Jenn Air parts here.
Your problem will be either the line fuse, or one of the thermal cutouts / TCOs in the unit.
In case it needs circuit board repair, see this link.
Nov 27, 2012 | Jenn-Air JMV8208AAS Microwave Oven
My Jenn-Air microwave JMV8208AAS will not heat the food and when turn on it makes a loud humming sound.
This is most likely the magnetron, the high voltage capacitor, or the power diode.
For an explanation on how these things are repaired, check out this website.
http://www.partselect.com/microwave+no-heat+repair.htm
If all else fails, call an Appliance Repair Technician.
Dec 09, 2010 | Jenn-Air JMV8208AAS Microwave Oven
Interior bulb went out , and it's an over the counter mount. How do I get to the bulb ?
Remove the top grill cover by gently pulling out on it and down on the right side. Remove the filter that is in the middle. Look at the metal cover, push back on the plastic tab and pull the metal clip toward you. You can now gently lift the cover off expsing the lightbulb and replace it. Simple and easy, no tools needed.
Dec 13, 2009 | Jenn-Air JMV8208AAS Microwave Oven
My jenn-air microwave makes a LOUD humming noise
More than likely the power inverter board has been damaged and it would be best to stop using it immediately.
Jenn-air products are very good quality and quite expensive to replace. I would contact Jenn-air service and have a service tech dispatched to determine the exact problem and the cost to repair it. Jenn-air stands behind their product 100% and should be able to repair the unit for you.
http://www.jennair.com/content.jsp?name=local_service_repair
Follow this link to Jenn-air service and repair.
Cheers,
Keith
Jan 02, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Change a JennAir JMV8208aa Microwave light bulb
Inside light
2. Remove grille.
3. Remove screws securing bulb holder.
4. Remove light bulb
Cooktop lights
2. Remove lamp cover or remove screws securing bottom plate cover.
3. Disconnect lamps.
If your bulb is stuck or physically broken, it can be a pain. It's sometimes tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
The lamps are available at most grocery stores, hardware stores, home centers, and places like Wal-Mart and Lowe's.
If the unit uses halogen bulbs, do not handle them with bare hands, as oils from the skin make them run hotter and shorten their lives.
Sep 21, 2008 | Jenn-Air JMV8208AAS Microwave Oven
JMV8208AAS Jenn-Air runs all by itself
check the door connection. it may be stiking. unplug from the wall and open up, spray wd40 and give it a clean.
Dec 13, 2007 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air JMV8208AAS Microwave Oven Logo
130 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
