Question about Dell Inspiron 1501 Notebook
The screen is not working it will however run an external monitor jus fine
  • 2,567 Answers
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Posted on Oct 06, 2010
Screen lights up, but no display dell precision m6300, display with external monitor
Looks like the LCD screen has gone bad as you are getting the display on the external Monitor.
Try This to run a test to check if it would still work or not:
1. Turn off the Laptop
2. Press and Hold the D key on the laptop and then press the ower button to turn it on..
3. Leave the D key when it starts
This would run the check on the Laptop and if you see the color bars then the LCD is fine, if not then you would need to get it replaced.
Check this article for more info about this test:
http://www.dell.com/support/Article/us/en/19/51934/EN
Regards
Anand Knowledge Base
Sep 07, 2014 | Dell Precision M6300 Notebook
Can i just remove the monitor assembly toshiba laptop p5085d-s8935 and just use a n external monitor
You could do that. Here is an excellent guide to replacing that model laptop's lcd which will show you basically how to remove it as well.
http://www.laptopinventory.com/LaptopInventory.php/Toshiba/Satellite/P505D-S8935/LCD
Dec 07, 2012 | Toshiba Computers & Internet
External monitor only works if I start windows vista in safe mode
First after you boot it up normally (not Safe Mode) can you move the mouse far to the left or to the right do you see the mouse. If you do see the mouse pointer you are running dual monitor mode and the laptop screen is set as the primary monitor. You have to run it in Save Mode and set the external monitor as the primary monitor. Hit the Start button then select Help+Support and in the search box enter "dual monitors". Read how to set up the primary monitor.
Second maybe you need to activate the external monitor. When laptops boot normally (not Safe Mode again) with a external monitor connected you have to hit the Fn (function) key (probably blue near Alt key) and some other number key (it probably has a blue monitor symbol on it) I'm not sure which one. This key sequence is a toggle sequence. In other words when you boot a laptop it goes directly to the laptop screen then the first time you do a Fn + number key combination it will turn on the external monitor and turn off the laptop screen the next time you push Fn+number key it will turn on both monitors (external and laptop screen) the third time it will turn on only the laptop screen and so forth.
Aug 19, 2012 | HP Pavilion dv7-1245dx Notebook
Laptop white screen
Maybe the lcd screen is going bad. Try an external monitor. if the external monitor works fine then your lcd screen on the laptop is going bad. If the external monitor behaves the same way, then the Video Card on the computer is going bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 01, 2012 | Compaq Computers & Internet
I have a Lenovo 3000 C200. I tripped while carrying it. At first the screen worked fine but eventually it only worked if the lid was 1/2 closed. Now it is so faint I can not use the screent and have...
IF THE LAPTOP IS WORKING FINE WITH EXTERNAL MONITOR THEN THERE SHOULD NOT BE PROB. WITH THE MOTHBOARD. JUS CHANGE THE LCD SCREEN AND IT SHOULD WORK FINE. PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Lenovo 3000 C200 Motherboard System board...
I have a fine horizontal line running 2/3rd's of my hp mini note book.should i be concerned?
This could be a hardware issue with the LCD screen of display card. To confirm the same, connect an external monitor and check if the same line appears on external monitor. If external mitor works fine, then its a LCD defect. If you have same issue on both LCD and External monitor, then it could be due to display card. In either cases you may need to take to service center.
May 22, 2010 | HP Mini 1000 Netbook
My laptop is not giving me display. i replaced the motherboard and lcd screen cable due to the motherboard and cable being damaged. i replaced with the appropriate models etc. the laptop runs fine...
Hello, Matt.
Sounds like a conflict with your VGA card driver.
From Safe Mode, go to Add/Remove programs and remove anything related to graphics. Go to Device Manager and remove/uninstall any listings for Graphics Adapter.
When you restart, install the drivers from the CD. If the drivers need to be "executed" as a program, cancel out of the driver install and run the drivers program when you get into Windows.
Hope this helps.
Jan 18, 2010 | Office Equipment & Supplies
When I turn on the aspire one note book it goes to a white screen and will flash once and go to white screen and stays there, owver all other lights on the panel flash normal, but will not boot up. this is...
If you're still under warranty, you can diagnose one possible problem easily enough. Blank white screen with the LED indicator lights running normally otherwise will almost always mean that the LCD panel is bad. If you don't have an external monitor available, find a friend with one and hook up the laptop to that monitor. Be sure to have the laptop power off when you attach the monitor cable. Press the power up button and then the Fn+F? (whatever F key has a little icon on iyt showing a monitor) combo to switch to an external monitor. If your laptop's Operating System shows up on the monitor, you know for certain it's jus your LCD panel that's bad and you can ask the manufacturer to replace it.
Dec 05, 2009 | Acer Aspire One PC Notebook
Blub
Sounds like the lcd screen has gone out . Hopefully you still havea warranty on it. But a good way to test if its the lcd screen or the graphics card is to hook it up to a external monitor and see if the pitcure comes up if it does then its the lcd if it doesnt then its the graphics or motherboard itself
Feb 13, 2009 | Acer Aspire 5315 Notebook
Random screen freeze
You are going to need your WINDOWS CD: http://www.updatexp.com/scannow-sfc.html
Dec 03, 2007 | Toshiba Satellite M45-S265 Notebook
Dell Inspiron 1501 Notebook Logo
171 people viewed this question
Alun Cox
