Hi there i am using lg wf-f712pc a top load washing machine and today i realised that the water did not drained out and the machine refused to spin after washing.... when i forcefully tried to turn the machine i realised the inner part is quite tight... previously it spins just like a wheel but now there's like a force holding it together.. i tried opening the back lid to check whether there's anything stuck but.. i can't find anything..maybe i'm not looking at the right place... where should i be looking ?? and what am i looking for ??? Thank you in advance : )
  • 343 Answers
Your machine won't spin because it can't drain.
You probably have a blocked drain hose or a faulty/blocked pump.
If you put the drain hose below the water level in the machine it may run by gravity. If it does flow this way it would show that the hose is not blocked (completely).
Make sure the machine is empty before continuing.
NOTE! Unplug machine from power supply!!
There is probably a small cover near where the drain comes out of the machine. Unscrew this cover and you will expose the pump filter, which may be (partially) blocked. Check for coins or similar which may be jamming the impeller blades..
NOTE! Any water in the machine will flow from here!!
TIP! Lean the machine forward to help contain the last of the water in the tub.
If the drain hose is clear and the pump is still not draining the machine you may have a failed pump motor.
Pump motor replacement is not a big job for an experienced tech.
Good luck....Nomess
Posted on Oct 06, 2010
Hi there ! I have a LG Top loader WF-T7030TP that wash the clothes but do not want to rinse,spin and drain the water.
you have blockage in your drain in the machine-possibly something stuck in the drain pump like a sock or a paper clip-tear it down-have a couple of old towels handy for the mess-cheers Denny
Oct 21, 2013 | LG WM Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
I have a LG WM0642HW it stopped draining, and sounds like pump is spinning but no water. I opened the filter plug and no obstuction and tried draining with small hose no water. but there is still water in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 17, 2011 | LG WM0642H Front Load
The spin cycle is not realising the waste water out of the machine
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 27, 2010 | LG WM-2277HW Front Load Washer
My lg WF-T552TH washing machine will not drain the water during a cycle just wondering how i can fix it??
heatman101
Oct 25, 2010 | LG WFT1071TP Top Load Washer
Water drain open even washing mode and during spin water not drain
heatman101
Aug 29, 2010 | LG Washing Machines
LG washer Model wf-t6517te not draining water
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | LG WFT1071TP Top Load Washer
Hi. i have had funny noises during last couple of washes. now washer wont drain programs are responding fine but washer keeps filling up and not draining.water backed up and came out of the drawer hotpoint...
heatman101
Aug 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
LG Washing Machine won't spin, signals that load isn't balanced
Check the drain clean out at the drain pump. If is cloggedm with debris, it will not spin and go off a a long drain error code.
Feb 06, 2010 | Washing Machines
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
