Question about LG 42LC2D 42 in. LCD HDTV
LG 42L850 TV TURNS PICTURE OFF AND ON BY ITSELF USE BUTTON FOR POWER AND IT GO OFF AGAIN PLEASE TELL ME WHAT TO DO
3 Suggested Answers
  • 35 Answers
SOURCE: I have a 32" HD AKAI TV that keeps turning itself off
Hi
This is power supply board problem.I saw on ebay chipper pries.Please check:
AKAI POWER SUUPLY BOARD LCT3201AD MLT169A
DS
Posted on Jan 16, 2009
caroldon
  • 17130 Answers
SOURCE: LG 50 PS 3000 tv will not turn on. Flashes a
Since your TV comes on and shuts off, the possiblity of the main power developing a fault on switch on to shut off as the error amp is asking it to do so.. Please check for any failure of capacitors in the HT section. use a multimeter and test voltage on switch on. make a note and test after it switches off. you will slowly arrive at the point of trouble. look for dry solder joints. use a good iron to carefully solder all joints suspected to look mushy. check the connectors of the HT drives to the panel. there could be fault in the connection resulting in slow build up and causing the error amp to react to shut off. Hope my advice helps. Good day
Posted on Jul 12, 2010
LG 32lg30-ud TV is entering commands at random as though someone where pushing the buttons. Also it turns on its own imedditly after being connected to the wall.
Main system control memory IC fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 10, 2015 | LG 32LG30 32 in. LCD HDTV
LG MZ-42PZ44
hi friend
u need a user manual see the in menual tell me whats ur tv model no
Apr 12, 2008 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
LG LCD 42" sound but no picture
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
Jan 17, 2014 | LG 42LC2RR 42 in. HD-Ready LCD TV
My LED LG TV 42" turns on/off by itself. Channels do not change.
Sorry to tell ya but your power supply panel or chip is going out! Mine done the same stuff! Freakin flat screens dont last as long as the older t.v's
Nov 01, 2012 | LG Televison & Video
My lg 42PQ3000 has a problem. The picture just dissapeared this afternoon but the sound continued. The remote control doesn't work except for the power button and when I try the buttons on the actual tv...
Try unplugging the power and then holding down the power button for a few seconds either on the remote or tv. I think this will reset the lcd tv. Tell me if this works.
-Ben
Jun 18, 2010 | Televison & Video
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
Tv turns off when I first turn it on
hi this s grizmofreak
solution to above problem
this s because of the secondary emissions of picture tube, and once the supply stops the emmissions from the picture tube wont stop for few seconds and horzontal scannin problem.
please do rete me on the above solution.
Feb 02, 2009 | Televison & Video
TV Turned itself off, and won't turn on...makes a chirping noise
try to check the menu your the timer is on.if not resolder the main board of your tv.
Oct 18, 2007 | LG 30FZ4D TV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
LG 42LC2D 42 in. LCD HDTV Logo
225 people viewed this question
Computer Repairing
Computer Repairing
