Question about GE Washing Machines
My washer is leaking big time. I've checked the pump and associated hoses and they look fine. How big of a deal is it to take the tub out and start checkinh in there?
I HAD THE SAME PROBLEM. I REPLACED THE PLUME (SP?) TOOK CARE OF MY PROBLEM. (THIS IS WHERE THE WATER GOES INTO THE TUB WHEN FILLING UP)
Hh
Posted on Oct 06, 2010
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
I have a Roper RTW4340SQ0 washer that leaks profusely when it fills and throughout the washing cycles. I've checked the water valve and all the hoses associated with it as well as the pump and all the...
This model is direct drive with a front mounted drain pump. The drain pump is THE most common leak location on these type washers! The pumps do NOT generally leak at the hoses, but from the impeller side between the pump and motor. There will be a telltale water mark on motor side of the pump shell.It can easily be fixed by popping the 2 retaining clips, removing the two drain hoses, and pulling off the old plastic pump, replacing it in the reverse order after cleaning the end of the motor shaft. Pumps run about 30 dollars. If you are sure this isn't the culprit, check for signs of leakage between the tub center and transmission, there is a tub gasket there. The tub itself, is not likey to leak, it is one piece with heat welded seams.Go to Youtube and search Whirlpool washing machine repairs, there are a number of instructional videos that show you exactly how to repair these machines and save yourself a lot of money. Incidentally Roper is built by Whirlpool, that's why I said search with that name.
Hope this sheds some light on the problem
kcomp1863
Jan 19, 2011 | Roper RAX4233PQ Top Load Washer
Whirlpool Mod # LSB6200KQC continues to fill with water and does not stop...it overflows. I also noticed that it started to leak from the bottom. Thanks for the info about the pressure hose switch. The top...
I already posted this under your original post.
The other end of the hose connects to the air dome on the lower right hand side of the outer tub. You will need to remove the outer washer casing to access it. Just follow the steps in the link provided:
http://www.fixya.com/support/r397094-replacing_water_pump
Another common source of leakage is the drain pump. These pumps are sealed units and are not serviceable. If they leak, they must be replaced. That's why I included the link above. The steps required to replace the pump, also include remove the washer casing.
If the air dome hose had come loose the leak would be significant. I could not find a diagram, either, but I did find the replacement hose under the "Agitator, Basket, and Tub Parts" section as item 19. The cost is about $8.
If the leak is coming from the wash tub, this is commonly caused by either a bad tub seal, or cracked tub. We'll cross that bridge, if needed...this is not a difficult repair, but it is time consuming. The seal itself is cheap, but a new tub costs over $100.
If the washer leaks from the rear of the washer, this is usually caused by a leaky water inlet valve, or associated dispenser hoses. The only way to tell is to remove the outer casing and notice where the drip patterns are. The washer will not run with the lid switch connector unplugged, so you will need to run a small amount of water into the tub before shutting it off and removing the case. This will aid you in locating anything associated with the tub or drainage. If the inlet valve is leaking, there should be noticeable water marks.
If this still does not solve your problem, please let me know.
PS No need to post new questions for the same job. Just add your comments/questions to your original post and I will receive email notification. This will save you the need to open an addtional post, and I will get notified without having to search for it.
Aug 10, 2009 | Washing Machines
Leaking from behind?
If the leak is coming from the back of the washer, the problem may be attributed to either a leaking water inlet valve, or the associated internal hoses that run from the valve to the dispenser. The following link explains how to access the inside of the washer and/or replace the valve (if required):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If the leak is coming from under the front of the washer, the problem may be the drain pump. These pumps can develop cracks and start leaking. they are non-serviceable and will require replacing is defective. The following link explains how: http://www.fixya.com/support/r397092-replacing_water_pump Inspect all internal hoses and hose connections as well. There are two drain hoses on the water pump, and several small hoses near the water inlet valve. These hoses can develop leaks over time. If the leak appears to be coming from the bottom of the wash tub, you may have a leaking tub seal, or cracked wash tub (worst case scenario). You will see tell-tale signs of water marks on the gearcase (transmission) if this were the case. On the lower right hand side of the wash tub is an air dome with a small rubber air hoses attached. Make sure this hose is still attached and has no leaks. The air hose can slip off the nipple it is attached to and water will begin to pour out of the washer when it starts to fill. This will be an "attention-getting" leak as water will gush everywhere. Double check the air hose just in case. If parts are required, you can purchase from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best deals.
If you have any questions about this repair, or require additional assistance, please let me know. I hope you find this helpful.
Jul 30, 2009 | Kenmore 24032\24036 Top Load Washer
Leeking water from some were not from hoses
Leaks on this model washer can commonly be determined by the following:
1. If the leak is coming from the from underneath the front center of the washer, it's usually caused by a leaking water pump. If the pump leaks, it is not serviceable and must be replaced. The following link explains how:
2. If the leak is coming from the central area under the wash tub, the tub seal may be leaking. You should see tell-tale signs of water tracks on the gearcase (transmission) if this is the case. Also inspect the wash tub for cracks. Since the outer tub is usually made of plastic, it can crack and develop leaks. This repair involves removing the tub. It's not difficult, but can be extensive. We'll cross that bridge if the time comes - post back and let me know and I can give you advice on how to repair and the parts you may need.
3. If the leak is coming from the right-hand side of the wash tub, consider the air dome. This is a small dome located on the lower side of the wash tub with a small air hose attached. This is how the pressure switch is able to determine the pressure change as the tub fills and turn the water off when full. This air hose can come loose, causing water to pour out while filling (THIS IS NOT A SMALL LEAK). If the air dome is till intact with no cracks the air hose can simply be reattached. If the air dome is damaged, the tub will require replacement.
4. If the leak is coming from the rear of the washer, you will need to check your water inlet valve and associated dispenser hoses. The following link explains how to access the valve and replace (if required):
Of course, your drain hoses are always suspect. You mentioned those hoses weren't leaking. However, if you have not removed the washer case and inspected them closely, you may want to double check them.
If you have any questions, please let me know. I hope this helps you locate your problem.
Jul 18, 2009 | Whirlpool LSR5132PQ Top Load Washer
Dumps water on floor
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 26, 2009 | GE WJSR2070B Top Load Washer
Amana washer model LW6501W2 leaks in front during fill up
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
Apr 01, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Oct 22, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Washing Machines Logo
20 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
