Gateway not starting up//giving reboot device option
    Scholar:
  • 56 Answers
If your PC is refusing to even try to start, I'd first suspect that your power supply has gone bad. Any good computer store should be able to sell you one for $20-25. There should be 4 screws that hold the power supply into the pc's case (it's the small squarish metal box in the top of your pc case). On some 'tool-less' Gateway desktops, there is just a plastic lever (usually green). Make sure your new supply is at least the same amount of watts as the old and that it has the same connectors (ide vs. sata, etc.), extra connectors are ok. Just replace the box, then plug all of the connectors back in, each type only fits one way so it's pretty difficult to make a mistake. About 1/4 of the desktops I'm asked to diagnose have a bad power supply. If the computer doesn't start up normally now, the motherboard (main circuit board) is most likely bad. It's not uncommon for a bad power supply to take out other components when it goes but usually it is just the power supply that is faulty. Good luck.
Posted on Oct 06, 2010
Startup screen
select the first boot option and press enter
Dec 02, 2013 | Gateway Computers & Internet
I need the start up disk to reboot my computer
HI,
Can you please give the make and model no. of your computer so that i can give you a disk.
Sep 02, 2008 | Gateway Computers & Internet
Ok so I'm fixing this Gateway M-6843 for a friend... When I turn it on it will try to boot but then it goes to a bios looking screen and says Windows Error Recovery at the top and it gives the options of...
It smees your windows having some problem. It might crash.
try to boot the PC from CD, repair the windows. if it cannot repair, then better do fresh loading.
Aug 21, 2010 | Gateway M-6843 Notebook
Problems loading OS in Gateway desktop
Normally installing the os on a different mechine, and then putting into another pc dosent work.
If the hardrive is the oringinal drive, which came with the system, and you want to install xp on, you will have to use a dos disk with fdisk on it, delete all partitions on the drive and create a new partition, then start loading windows, it will give you the option to format the drive for nt(ntfs) file system and setup windows.
If you do that and it still gives you protecting files error, you will have to take the side panel of the computer tower, unplug from the mains and take the cmos battery out for about 30 secs, put the battery back in, plug in the mains and reboot the computer, start loading windows again
Hope this helps and post back if you need further assistance.
Feb 19, 2010 | Gateway GT5220 PC Desktop
Start up problems
did you add any device recently or installed a program before this happened? If your response is yes, then take out the device and try to restart. else, retsrt your system and press the F8 key to show you the boot options. start the computer on safe mode, and remove the newly installed program or roll back the system to a safer date when your system had no problem. Cheers!
May 19, 2009 | Gateway 420GR PC Desktop
Reboot to original settings
start in safe mode, then restart it normally
Feb 27, 2009 | Gateway Profile 4M PC Desktop
Gateway laptop dvd drive does not start
http://support.microsoft.com/kb/314060/EN-US/
Dec 25, 2008 | Gateway (5500652) (  5500652)...
Cant see gateway inscription when my machine is put on
try using the msconfig option. To do this boot your system then under start menu>run>msconfig Try unchecking programs you do not use regularly in the start up options, then reboot. Hope this helps.
Dec 19, 2008 | Computers & Internet
No Sound
did you install anything before this problem started? if yes try to uninstall it. if not, check device manager if your sound card drivers is still installed and if it is enabled. to go to device manager right-click Computer then click Manage. look for device manager then sound.
if it's enabled and there are no problems to the sound card go to control panel then Hardware and Sound. click on sound then check if the default digital output device is selected and enabled.
if it still won't work last option is do a system restore. set the restore date before the time the problem happens.
May 27, 2008 | Gateway GM5620 PC Desktop
Wont start windows
hi there, yes you need to back up data and the drivers for that, a clean installation of software is recomended. ty
Dec 29, 2007 | Gateway 7310S PC Desktop
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
