Hi how do i turn off hotel mode on my sony bravia KLV-32EX600
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
SOURCE: I have a sony bravia KLV-40U100M with no power
tv smoked and will not power on
Posted on Jul 05, 2009
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
welcomejee
  • 10594 Answers
SOURCE: 8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Posted on Feb 09, 2010
yourstupid
  • 4 Answers
SOURCE: the standby button is flashing twice- sony bravia klv-40v550a
Unplug the power cord for 30 min, plug back in and turn on.
Should ths not work seek repair or replacement
Posted on Apr 10, 2010
How to connect antenna to klv 40u100m
Correct. You have to connect the antenna to another box and then take the output of that box to the TV. An old VCR is ideal as this box.
Dec 20, 2013 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
On my Sony Bravia KLV-S40A TV I have a message "VIDEO 1". How do I get it off the screen?
On the original SONY remote press display to remove that---if left on long enough it will actually burn that image into the screen--button on almost any Sony Tv remote will remove or clear it.
Oct 25, 2012 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia kdl40ex600/32ex600 - only 4 months old, has just turned itself off and now red standby light is flashing - intervals of 7 flashes. Tried several things on the web without any luck. We are not...
If this set is under warranty you should return it to get it repaired/replaced by the seller. Let them pay for repairs. If not then;
This sounds like the power supply board is failing. The electrolytic capacitors on the board may need to be replaced.
Mar 04, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia KLV-V40A10 When turning the tv on the on switch flashes 7 times then turns the TV off. Thanks
sony bravia klv v40 schakelt op willekeurige sijden ove rop slaapstand. lampje knippert dan 8x en vervolgens 4 sec. puaze en op nieuw knipperen.
Aug 07, 2010 | Sony Televison & Video
Tv don't turn on at all!
The U series has two boards and it could be either the system/video board or the power supply board. It will take a tech to tell you which is bad
Oct 17, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony BRAVIA KLV-40U100M Issue
Just bought the KLV-40U400M Sony Bravia Monitor. Did you fix the turn on turn off problem? How much did it cost, labor/parts?
I'm thinking I better get the extended warranty although I wonder if the board will continue to go bad year after year.
I was told the tv could be replaced but w/someone else's refurbished tv. I was very unhappy w/that response.
So how's your tv today?
-Capri
Nov 03, 2007 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Televison & Video Logo
362 people viewed this question
Top Televison & Video Experts
