Question about Sharp R-1480 Microwave Oven
Sharp 1440 microwave stopped working last night no clock nothing. all ready checked the plug n its good.
  • Sharp Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 06, 2010
I used my sharp R-1821 convection microwave that night it did not work. outlet is lit up but display does not come on. Why?
More than likely it will be one of the three door switches. Also check the internal fuse in the unit. The fuse if blown is just a symptom, not the problem. It doesn't always blow out but the right combination of switches bad will take it out.
Dec 03, 2014 | Sharp Microwave Ovens
I have a 1995 Sharp Carousel R-1440. Our power went out then when it came on our microwave it no longer working properly. the clock works but when the door is closed the cooling fan starts running- it...
Yes your oven's controller is probably malfunctioning you need to replace the SYSTEM BOARD but I personally suggest to buy an other oven.... the system board will be hard to find and expensive...
See if other electronics is acting funny since the power loss... you could CLAIM the damage from the insurance company
Good luck!!
Feb 28, 2011 | Sharp R-1460 Microwave Oven
I have the Sharp R-1440 carousel microwave oven and it won't shut off when I close the door. Do you know how old this oven might be? Model R-1440; Serial 123662
Check and change door interlock switches or check for condensation problem on control panel, (internal).
Hope that helps.
Feb 02, 2011 | Sharp R-1480 Microwave Oven
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Sharp Carousel Model R-1440 won't shut off
Take it immediately to a local Microwave repair shop...looks like one of the circuits may have gone...otherwise switch off from mains
Sep 28, 2009 | Sharp R-1480 Microwave Oven
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
Sharp R-405k microwave stopped cooking
Well, it sounds like a bad relay. Easily fixed by a repair shop.
May 05, 2009 | Sharp R-405KS Stainless Steel Microwave...
Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com (the three is correct)
Jun 04, 2007 | Sharp R-202EW Microwave Oven
Sharp R-1441
There should be a "CUSTOM HELP" or "HELP" pad on the keypad. When you press that, "CHILD LOCK" should be the first option. The display will guide you to press 1 or 2, etc., to turn it off. We don't have an online copy of that manual, but it's part number TINSEB114MRR0 (zero on the end). You can order it via Tritronics at http:/www.wehaveparts.com
Oct 04, 2006 | Sharp R-1871 Convection Microwave Oven
Sharp R-1480 Microwave Oven Logo
162 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
