Question about Panasonic KX-T7730 Corded Phone
I have to change the time showing in my Panasonic KX-7730 Corded Phone
SOURCE: Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
Posted on Apr 08, 2008
  • 108 Answers
SOURCE: Panasonic KX-T7730 corded
If you can provide the phone system type I will try to help as this is a system wide setting and there are a lot of different Panasonic systems out there. ......Mike
Posted on Aug 02, 2008
ybchuan
  • 201 Answers
SOURCE: Hi, How do you change the time on a Panasonic
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Posted on Oct 19, 2009
cnavarro
  • 2460 Answers
SOURCE: Time Change
It can be changed from any phone that lets you into programming. We usually give everybody access to make changes like this, but by default, the phone designated as the Manager or Operator is usually given that access. Try ext 101.
When you get there, press PROGRAM **1234. If your display reads SYS-PGM No?, then it will work. Dial 000 and STORE. You will see the Date. Press SP PHONE! Now you will see the time. Dial the new time and press STORE. Press HOLD and PROGRAM to exit or just pick up the handset and drop it back down.
If for some odd reason you can't get into programming from ext 101, then you might have to search for the manager's phone, or call your installer to make one or all of the phones have access to programming.
They can allow you access to other programs, or even give you the installer password to get into all the programming.
Carl
Posted on Oct 29, 2009
Testimonial: "Thanks, great help"
Phonesmith
  • 113 Answers
SOURCE: HOW DO I CHANGE THE TIME ON A PANASONIC KX-T7730
If you are using the KX-T7730 phone with a Panasonic KX-Txx 308/616/824 system. From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done.
Please rate this answer if it was helpfull.
Thank you.
Posted on Mar 23, 2010
I would like to change the ring numbers on my Panasonic KX T 7730 from two to four or five because sometimes it's impposible to get to the phone that fast
You need to enter the programming mode from the default EXTN usually 20 or 21 and change the timings of the ring counts, normally shown in seconds, adjust to 30 secs which should give you the amount of rings you need if not just go back and adjust the ringing counter seconds up until you find the length of time that suits your needs.
Aug 31, 2013 | Panasonic KX-T7730 Corded Phone
Answering machine message
The KX-T7730 isn't an answering machine. You need to refer to the documentation for whatever answering/voicemail system you have it connected to. Alternatively, repost your question specifying the make and model of the answering/voicemail system.
Jul 30, 2012 | Panasonic KX-T7730 Corded Phone
Is there a voice mail feature on this phone? Panasonic KX-T7730 Corded Phone
The phone is stupid. However, there could be a voice mail feature in the system the 7730 plugs into. Panasonic makes both internal and external voice mail systems that attach to the various KX-T systems.
Carl
Nov 03, 2011 | Panasonic KX-T7730 Corded Phone
I have use llinksys PAP2T togather with Panasonic KX-T7730c. does it possible?
Gather what? A PAP2T is a 2-port FXS box. A 7730 is a phone that works on a Panasonic Key Service Unit. You can plug the CO lines of a KSU into the PAP box and the 7730 into the KSU and get dial tone on whatever line you used on the PAP if that's what you're asking.
Carl
Mar 24, 2011 | Panasonic KX-T7730 Corded Phone
How do I record or change a recorded message on the Panasonic KX-T7730?
A Panasonic 7730 phone operates on 18 different Panasonic Key Systems. There are 5 or so different ways to record a message...which one is yours?
The 7730 was first delivered with the TA-824 system. It has the ability for announcements via DISA, which was built in to the USA versions of the TA. It's recorded or changed via the master phone and PROGRAM 911.
A Panasonic TVA or TVS voice mail system does auto attendant functions. It can have both company greetings and custom service messages. Those are changed via mailbox 998, the message manager's box.
Last, the newer system also have "bulit-in" voice mail boxes. Those greetings are recorded by 722xx commands.
Carl
Dec 13, 2010 | Panasonic KX-T7730 Corded Phone
I need to know how to pick up another extension I have Panasonic KX-7730 corded phone.
If it's wired to a TA series cabinet, you can do it in 2 ways. On the intercom 40 picks up the ringing phone(s) in your group, and 41xx picks up the specific ringing phone. In a small office, 40 usually works fine.
Carl
Oct 04, 2010 | Panasonic KX-T7730 Corded Phone
Hi i bought my new panasonic KX-T7730 but when i bring it home and try to make a call its not working there is no dial tone can u plz help me
Did you just buy the 7730 or do you have other ones in your house? Since a 7730 is designed to plug into a Panasonic SYSTEM, you'll be waiting a long time to make it work if you're plugging it into a regular phone line :-)
Carl
Sep 28, 2010 | Panasonic KX-T7730 Corded Phone
Free instruction to record my voice kx t7730
The 7730 is a PHONE. It connects to a Panasonic PHONE SYSTEM CABINET and Panasonic VOICE MAIL SYSTEM. The voices you hear are stored in the VOICE MAIL SYSTEM and it varies by model number and installation. Typical messages are stored in CUSTOM SERVICE menus, of which there are
100.
It is changed by accessing mailbox number 998 as message manager.
Carl
Dec 18, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX - T 7730
look.................. a *****
Jun 19, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
