Question about HP Photosmart 3210 Printer
Can this printer be adapted for bluetooth? - HP Photosmart 3210 Printer
    New Friend:
  • 42 Answers
No, however, there are similar printers in the c7000 and c8000 series that include bluetooth. Even so, it can only print basic text from cell phones that support the feature, so it is really useless.
Posted on Oct 06, 2010
How do I make my hp officejet 100 discoverable
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
Sep 11, 2014 | HP Officejet 100 Mobile Inkjet Printer,...
P350 lexmark saying that a memory card is not present yet it is.also blue tooth on phone cannot connect to printa allthough it is all turned on.
Make sure you are inserting a compatible memory card for your model. Below is the list of compatible digital media memory cards for the Lexmark P350 printer:
  • CompactFlash I & II
  • Sony Memory Stick, Memory Stick PRO
  • Secure Digital (SD) Card
  • MultiMediaCard (MMC)
  • xD Card
  • Sony Memory Stick Duo (with adapter)
  • Mini Secure Digital (Mini SD) Card (with adapter)
  • Sony Memory Stick PRO Duo (with adapter)
  • SanDisk TransFlash Memory Module (with adapter)
  • RS-MMC (with adapter)
Guidelines to print via bluetooth:
  • You can print photos from a Bluetooth-enabled device such as a camera phone using a USB Bluetooth adapter.
  • Make sure that the Bluetooth Enable and Discovery Mode selections on your printer are set to On.
  • Insert a USB Bluetooth adapter into the PictBridge port on the front of the printer.
printmastert_72.jpg Note: Bluetooth adapter sold separately.
  • Once the printer detects the Bluetooth adapter, the following message appears on the printer display for five seconds: Bluetooth Dongle Connected.
  • To print photos from your Bluetooth-enabled device, see the documentation that came with the product.
Aug 15, 2011 | Lexmark P350 InkJet Photo Printer
Will this adapter work with a All in one 5500 printer?
Hi as long as the printer is bluetooth capable then this dongle will pick up the signal and it will then let you use the printer.
you should have no problems using it as long as you have the printer software installed on your computer and you also need to install the drivers for the usb bluetooth once you have done this you need to make sure the printer is switched on then you need to scan using the bluetooth software then just connect with the printer, this will then pair the devices and will let you use the printer via bluetooth
let me know how you get on or if you need further assistance.
plz can you rate this solution as i have pages on unrated posts filling my page, thanks
Aug 25, 2010 | Kodak (1723949) Bluetooth Wireless Adapter
How do i set up bluetooth connectivity
If you have Windows XP with Service Pack 2 or 3 installed on the computer, then the computer has the Microsoft Bluetooth Protocol Stack. The Microsoft stack allows you to install an external Bluetooth adapter automatically. If the Bluetooth adapter supports the Microsoft stack but it does not install automatically, then you do not have the Microsoft stack on the computer.
>>Make sure that you have installed the HP All-in-One software on the computer.
>>Attach an HP Bluetooth adapter to the front USB port of the HP All-in-One.
>>If you are using an external Bluetooth adapter for the computer, make sure the computer is on and then attach the Bluetooth adapter to a USB port on the computer. If you have Windows XP with Service Pack 2 or 3 installed, the Bluetooth drivers are installed automatically. If you are prompted to select a Bluetooth profile, select HCRP.
On the Windows taskbar, click Start , and then click Printers and Faxes .
>>Double-click the Add Printer icon.
>>Click Next , and then select A Bluetooth Printer .
>>Print as you would to any printer.
Regards
Riztech.
Mar 31, 2010 | HP Photosmart C6180 All-In-One InkJet...
How do you connect printer to laptop with bluetooth
Hi friend,
follow the given below instructions-
1-Make sure your printer is Bluetooth enabled. Some printers come this way (read the manual to verify) but others require adapters. Shop online or visit an electronics store to find an inexpensive Bluetooth printer adapter.
2-Set up your adapter. All you need do is connect one end to your laptop and the other end to your printer and it will install itself.
3-Turn on the printer. Make sure it is connected to a working electrical outlet and the printer power is on correctly.
4-Open Bluetooth devices on your laptop. After installing your Bluetooth adapter, go to the control panel and open "Bluetooth Devices."
5-Add printer automatically. This is less secure, but easier. From the options tab, make sure the options "Turn discover on" and "Allow Bluetooth devices to connect to this laptop" are checked. Your printer and laptop should then find each other automatically and begin working. If you'd rather not let other devices discover your laptop, follow steps 6 and 7 instead.
6-Add device manually. From the devices tab, select "Add Device" and run the installation wizard to find your printe
7-Use the "Add Printers" wizard. You can also add the printer by clicking "Start" and "Printers and Faxes" and then "Add a Printer." When the wizard pops up, select "Bluetooth printer" and Windows will search for your printer automatically.
please rate me........
Thanks,
Mar 24, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
RE: Canon Bu-20 bluetooth printer adaptor. I just purchased one and there are NO instructions in the package. Do you know of an instruction page/manual?
With my MX850 printer the bluetooth setup instructions were only in the on-screen printer manual, not with the bluetooth adapter, and not with the printer documentation.
In my case it didn't help as Windows is not discovering the bluetooth adapter for some reason.
Jan 08, 2009 | Canon BU-20 (13803055436) Print Server
Problem in taking a print from Nokia 3500 using kyocera printer attached with Bluetooth adaptor
Check your Bluetooth adapter and see if it requires driver. If it requires driver then you can't just plug it in to your printer unless your printer has a built-in drivers for Bluetooth adapters.
Check if the printer supports Bluetooth adapters and make sure that your Bluetooth adapter is compatible with the printer.
Jun 25, 2008 | IOGear Bluetooth Combo Printer Adapter [...
I have a HP Photosmart C7280 and a new MacOS 10.5.2 Both have Bluetooth. I'm unable to establish a connection. The setup asks if the printer is" discoverable". How do I make the printer...
Hi JGross1638,
Unfortuneatley, the C7280 does not have bult in bluetooth. It has normal built in Wireless 802.11g technology. In order to make the printer bluetooth, you can use an external bluetooth device to make it that way. The C8180 is the next model up that includes 802.11g wireless technology as well as bluetooth wireless technology.
This is the bluetooth adapter: http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-236253-34210-396578-459962-465649-459963.html
If you already have the adapter, you might want to try reset the bluetooh settings on the printer. Be default, the printer is setup so that any bluetooth device can print to it. So, if you've played around with the settings then you should just have to reset them.
To reset the bluetooth settings, scroll through the main menu until you get to "Setup" and select it. Scroll through the setup menu and select, "Bluetooth" (This option will only appear if you have the adapter installed). Scroll down until you see "Reset Bluetooth" and that will reset it.
Here is the link to the manual: http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-236253-34210-396578-459962-465649-459963.html (Bottom of page 35 for bluetooth reset.)
I hope this helps,
-Ernest
May 06, 2008 | Office Equipment & Supplies
Adding bluetooth to toshiba laptop
Well,I'm not really an expert on Bluetooth, but let me try...
Which version of Windows are you running? If you have Windows XP SP2 or above, the Microsoft Bluetooth stack should be installed on your system. First make sure that the Kensington bluetooth adapter is compatible with the printer and the OS. From what I heard Canon sell a separate Bluetooth adapter for about $80 for this, but I'm not too sure.
Secondly, ensure that the built-in Bluetooth Stack or Software has the required Profile for your printer.
Next, put your printer in "discover" mode (see printer manual for more info ). Use the Bluetooth Connection Utility software that came with the built-in Bluetooth stack to "discover" the printer. Follow the instructions by the Bluetooth stack manufacturer on how to pair and connect Bluetooth devices to your built-in Bluetooth stack.
Please also see THIS article. although it is meant for the Logitech DeNovo keyboard, it can be used for any Bluetooth enabled devices. (Just replace the DeNovo wit your printer in the article.
But mainly, make sure that the Kensington adapter is compatible...
Hope that helps..
IrishDruid
May 04, 2008 | Toshiba Satellite A135 Notebook
HP Photosmart 3210 Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
