Question about Dryers
Hello!! My dryer is making small holes to my clothes. Sometimes i also get a rustlike stain, usually a straight line. Is this a common problem. Is it worth fixing? My combo is about 7 or 8 years old. I already fixed this problem once. Is it going to keep happening? Thank you very much!!! Ilia M.
  • 3 more comments
  • iliamar Oct 06, 2010
    kenmore model 417.90812991 i called sears they say this model doesnt bring a felt seal. Perhaps something similar. When u reply besides saying the part name please explain briefly what the part looks like and were it is located. Am i going to be able to replace this part myself? Could the holes and the stains be caused by overheating? I have never seen the clothes stucked. Thank you.
  • iliamar Oct 07, 2010
    What do you mean "pop up the top open" -open the front door?, There are about 3 or 4 screws on top of the front panel, is that all I need to unscrew and the front panel will come out? What is the door switch and how do I disconnect it? Is there a trick to placing and glueing the glide and seal? I wouldn't want to mess it up and end up spending more. I am a spanish female, even thouh I am pretty handy I've never done this before and the parts in english are a bit harder for me to understand. So sorry if I ask too much. Thanks for your help. Ilia
  • iliamar Oct 13, 2010
    I finally got the parts, however the process isnt as easy as you described it. I took the top screws off and the front panel didnt completely come off. Just the top part. I had to start searching for other screws at the bottom to see if i could remove the whole thing. I found other screws at the bottom of the panel and unscrewed them. Then the smallest panel were the buttons are kind of came of. Thats when i finally saw the wires you were talking about. Meanwhile the front panel is still hanging and i am alone with no one to help me to hold it until i could see if i found another set of screws since the panel coulndnt come out because it has a bigger part that needs nore disasembilng before being able to completley remove. I am not able to put the whole thing back because i am alone. I decided it was more difficult and risky than i thought. I dont want to mess up my dryer. I called a technician that will be here hopefully this afternoon. I really appreciate your effort. But you made it seem a lot easier than it actually was. FixYa is charging me $12 when i thought the charge was only $6 and i am hesitant to even pay that
    Because now i have to pay a technician anywyas. If you can give me clearer instructions on the steps i already made and i am able to fix it myself before the technician gets here. I wont mind paying. I can can get somebody to help me hold things while i keep unscrewing. I wish i can send a picture so you could see what i mean.
    President:
  • 1,554 Answers
It is a common problem and caused by worn felt seals which allow the clothes to get caught between the bulkhead and the ends of the drum. The only viable solution is the replacement of the worn felt seal. Indicate the exact model number of the machine for further advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting a solution will not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 06, 2010
  • Jahn27
    Jahn27 Oct 06, 2010
    You dryer has the upper front felt glides and the lower front felt seal with part numbers 5303937139 and 5303283286 respectively. They are located glued on the inside of the front panel where the front edge of the drum rests into. Pop up the top open then remove the screws securing the front panel to the cabinet and pull it away after disconnecting the door switch. Remove the old worn seal or glide then glue the new one in place.
    For more information on the locations of these parts, refer to item numbers 20 and 23 on the http://c.searspartsdirect.com/lis_png/PL..." target="_blank" rel="nofollow" >exploded view diagram.
    Exploded View Diagram
  • Jahn27
    Jahn27 Oct 07, 2010
    "Pop up the top open" means raise the top cover to have access to the front panel screws securing it to the cabinet. Once the screws are removed the front panel can come off.
    The door switch is the one that the door activates when it is closed, a switch that the door activates. Disconnect the wires from its terminals before you can remove the front panel.
    There's no trick in gluing the felt seals to the front panel. Just make sure the old felt is totally removed with no residue left on the front panel.
Why does my fride leak constantlay (into and also to the outside onto the floor) and it is a orange - rustlike color substance that stains both my fridge and the floor.
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 07, 2015 | Refrigerators
Washer leaves stains on clothing
Many times when we cook in the kitchen, we get splattered with oils that aren't easily visible. Very often these oil spots pick up dirt from the wash water. These stains don't usually get noticed until after the clothes have been dried. The best thing to do is to rub detergent or stain remover right on these spots and let them sit about half an hour. Then rewash the clothes in as hot water as the material can take afterwards.
Aug 11, 2008 | Whirlpool Washing Machines
How to get ink stains from the inside of a dryer?
Hi jchbell
Take the dryer out to a well ventilated area.
Wear gloves, use a rag dampened with Lacquer Thinner and hold your breath alot...
Wipe the ink stains with the Lacquer thinner and it will remove most all of the stains to the rag.
Please take time to rate me
Sep 05, 2011 | Dryers
My gas dryer smells like fuel sometimes.The clothes are drying but have a fuel smell so I have to rewash them. This happens every so often, not all the time. What is it?
did you paint or stain anything in the house or gas stored near the dryer?usually if you did the fumes get into the dryer and onto the clothes,if the motor is overheating that will also smell like shellac
Mar 08, 2011 | Frigidaire Dryers
Why does my washing comes out with stains on it.... they weren't there when it went into the wash...
yes sometimes ink pens can be washed when we are not aware it was in someones pocket. I use straight ammonia and a cloth to clean my washing machine drum a couple times a year because these things have happened to me before. The ammonia will cut the grime and pen stains out of the drum. Then take a squirt bottle and fill it with white vinegar and squirt all around inside the drum of the machine. Run a wash without any clothes with the hottest water to clean the drum and clear out the stains. Do this to the dryer also and clean out the filters. Take the dispensers out from the washing machine and clean those too and your cleaning is done for a while. Apparently the ink has been in the drum of your washing machine and putting the color into your clothes. You can bleach out the white clothes that turned blue. Use the stain remover for colored clothes. Hope this will help you.
Feb 01, 2011 | Whirlpool Washing Machines
Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
Dryer makes small holes (cigarette burn size) on clothes
Get a new dryer. Old ones tend to tear-up clothes and burn holes.
Apr 29, 2009 | Dryers
Holes in clothes
I'd bet the holes are the same size as the holes in the dryer tumbler. the only thing I can think of is that your dryer isn't tumbling and the heat that is pushed through the holes is burning your clothes.
Apr 18, 2009 | Miele Novotronic Premier 500 Front Load...
Clothes dryer
It could be rust stains coming from the tub of the dryer during the drying cycle. The only concern is that rust stains are usually brown streaks on the clothes. I'd check the to make sure there are no rust stains on the tub, check the seal of the door to make sure its still in good condition. The last possibilty could be a good cleaning of the dryer (removing lint from the lint screen compartment and the tub of the dryer).
A schematic of your dryer can be found on www3.sears.com and should show how to get into your lint screen compartment and your tub.
Feb 07, 2008 | Zanussi TD4100W Electric Dryer
Dryer damaging clothes
Call repairman if you are not mechanically inclined it will be worth the money spent.
Oct 29, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
