Question about Gestetner DSc332 Copier
GESTETNER DSc323 - SUPER G3
I have a printing problem, the message displayed says" Following Output Tray is Full Remove Paper Standard Tray"
I have removed all the paper from the printer, where else do I look? I don't have a manual and there isn't one available on the internet.
Help, please, This has caused my printer to shut down until the paper is removed. But, where do I locate this output tray?
If you look at the paper exit you will see 4 white exit wheels
in the middle of the 2 center ones you will see that there is a black
lever. This needs to be pushed back into position so that it is horizontal to the exit wheels.
Hope this helps regards
Myott
Posted on Jun 01, 2008
How to output bin empty ?
  1. The output bin may be full. Empty the output bin. Printing resumes automatically.
  2. Take a close look at the flaps hanging out the exit of the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, then a bin full error is displayed.
  3. Open rear exit tray and power on the printer. If the printer comes to a Ready state, close rear tray and try printing.
  4. Clean the paper path below the toner area and exit assembly at the back of the printer. Ensure there is no pieces of paper stuck in the paper path of the printer.
Jan 20, 2015 | HP LaserJet 5200 Printer
Standard bin full
This error is cause by either having your output paper bin full of paper or the flag sensor out of alignment where the paper comes out of the top. Look at the top f the printer where the paper comes out and you should see a black plastic sensor flag, it should move freely. If it is stuck remove the top cover above it and try to free it so it can move. Below is a picture of the printer with the output sensor flag circled.
Feb 02, 2013 | Lexmark T632 Laser Printer
I receive the following message on the PC display: "Document printing cannot be executed because the paper output tray is closed. Open the paper output tray. Printing will restart". I want to mention
The blinking is just an attention light so there's nothing to worry about that. Try adjusting your paper tray to the paper size you are about to use. Or try checking the duplexer panif its positioned properly. Hope this helps.
Dec 20, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
The display says following output tray is full.
Look at the area where the paper just exits from the machine. You should see a small black plastic arm. Make sure it has not become stuck in the up position or knocked out of place. This arm is what tells the machine that the area is full of paper. Also your machine is the same as Ricoh 1022, Savin 2522 in case you need to do more research.
Oct 19, 2009 | Gestetner 2212 Digital Imaging System...
Canon super G3 Fax display message continously "Check paper size"
my fax give the message "check paper size" I' clean the all sensors' end nothing
Apr 25, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Standard Try Full
'Standard tray full, remove paper' is the output tray where the prints exit.
Check also the exit sensor/feeler condition.
Good luck and please rate me, thanks.
Sep 05, 2008 | Ricoh Aficio SP C811DN-DL Printer
CL7000 copier/printer problem
hi im jules_09,there must be a small piece of paper stocked at the output tray.see if you can open the front door then full out the fusing unit somtimes paper is stocked in it.then while the fuser or fusing unit is out check the output tray if there is a paper.in the fuser unit check the hotroller or upper roller its a black metal roller that heats up
Nov 08, 2007 | Office Equipment & Supplies
Error message for Ricoh C410DN
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Oct 30, 2007 | Ricoh Aficio CL2000N Laser Printer
361 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
