Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 All In One Printer
I just finished installing a new Printer Carriage Assembly. Everything seems alright except now the Color Graphics Display doesn't come on at all. It prints but no video on the display. Is there a solution to this?
    Novelist:
  • 79 Answers
there might be a hardware issue with the LCD however u can try to reset the printer by the following steps .
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
Thanks
Posted on Jun 03, 2008
Why does my hp 7410 all in one ask me to remove and check color cartridge?
Yeah, as I am a victim to this very same problem, the other guys are right. The metal spring that is part of the ink carriage becomes a hole punch for the ribbon cable right behind the unit. Now you have a useless printer that you think has faulty ink cartridges, but in fact it's a faulty printer. Because of this design flaw, HP should compensate each and everyone of us, no matter how long ago the purchase of the printer was. I bought mine in 2006 for over $600 and for such a little thing that will break at some point, causes such a huge problem. It's caused by you putting the ink cartridges into the unit. You don't have to be aggressive with the install for the failure to occur, normal installs will cause the same affect. My suggestion to you my friend is to put it up for auction on eBay and use that money for a new printer. Gots me a HP OfficeJet Pro 8600 Plus that was 1/3 the cost of the 7410, with pretty much the same features and more!
Jun 06, 2014 | HP OfficeJet 7410 All-In-One InkJet...
Have an HP PSC 1510 printer. I put in a new genuine HP Tri-Color (93) printer cartridge as I usually do and the "Check Printer" cartridge started flashing. Also flashing on the printer is the...
Problem After you install a print cartridge, one of the following messages appears on the color graphics display:
  • Incorrect Print Cartridge
  • Incompatible Print Cartridge
  • Problem with the Print Cartridge
  • Remove and Check [color / black or photo] Cartridge
  • [Tri-color / Black or Photo] Print Cartridge Inserted Now is Not Intended for Use in This Printer
NOTE: In the procedures below, the "problem" cartridge is the one identified by the message on the color graphics display. If the message does not specify a cartridge, perform the procedures on both cartridges. Step 1: Remove, inspect, and reseat the problem cartridge The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help.
NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, then wait until the print cartridge carriage is idle and silent.
  3. Press down lightly on the end of the problem cartridge to release it. Figure 1: Removing the tri-color cartridge
  4. Slide the cartridge out and inspect it:
    CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 2: Electrical contacts and nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear nozzle protective tape has been removed.
      CAUTION: Do not attempt to remove the copper electrical strip! Figure 3: Removing the clear nozzle protective tape
    • Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
  5. If the cartridge is compatible, reinstall it in the printer:
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
Step 2: Clean the problem cartridge contacts
  1. Gather the following items to clean the cartridge and carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or a paper towel to rest the cartridge on during cleaning.
  2. Open the product cover and wait until the carriage is idle and silent.
  3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
    NOTE: Clean the contacts quickly so that the cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
  4. Unplug the product from the electrical outlet.
  5. Dip a swab in the clean water and squeeze it to remove most of the moisture. The swab should be only slightly damp.
  6. Clean the cartridge contacts.
    CAUTION: Do not touch the ink nozzles.
  7. Clean the contacts in the carriage, inside the product.
  8. Either let the cartridge sit for 10 minutes to allow the cleaned area to dry, or use a new swab to dry it.
  9. Reinstall the cartridge.
  10. Reconnect the product to the electrical outlet.
  11. Close the product cover.
Step 3: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above.
Call HP if the cartridge is covered under warranty to replace the cartridge
or its time for a new printer
Apr 04, 2011 | HP PSC 1510 All-In-One InkJet Printer
I have a 7410 hp office jet that broke when i tried to replace the ink cartidge. a little tab broke off and went through the back of the curcuit paper thing. this has had very light use. I have seen many...
Yes, there many complaints of the same thing, once that ribbon cable is torn, the only repair is a new carriage assembly, if you can find a new one it will cost more than a new printer.
Dec 29, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Im trying to get it to print copies only blanks so far
You can make multiple copies by loading them print side up into the upper feeder you'd use to fax, then entering the number of copies on the keypad and hitt the copy button for color or black
or you may lift up the carriage and place a page on the scanner glass, close the carriage select the number of copies and hit the copy button for color or black
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Replacement instructions for ink cartridge carriage assembly
Please follow the link below to HP Web site. This will take you to the HP 7410 Setup Chart. The cartridge instructions you need begin in frame 10.
http://h10032.www1.hp.com/ctg/Manual/c00236206.pdf
Don
Oct 22, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Printer does not recognize new color cartridge
Make sure you have taken the orange tape off the print cartridge.The printer will not recognize the cartridge with the tape on
Mar 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Replacing carriage assembly
What part of the Carrage assembly to you want to replace. Belt Motor scanner bulb.
May 30, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
166 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
