Says fuser error 50.2 turn off and on? why is this and how do i fox it
    Problem Solver:
  • 7 Answers
This is a hp error for a broken fuser unit. You need to post more info for anyone to give a firm answer, ie make and model of machine and when after power on does the error message show. If you have a HP, then your fuser unit is not reaching temperature by the required time. Most likely the ceramic heating element is blown.
Posted on Oct 06, 2010
50.0 fuser error
SOLUTION: Follow the steps listed below:
  1. Turn the printer off and unplug it for 30 minutes; then turn the power back on.
  2. Try a different power cord. DO NOT use extension cords to plug the printer in.
  3. Remove the surge protector or UPS/CVT device and connect the printer directly to a power source.
  4. Try a different electrical circuit. There could be an issue with the line voltage going into the printer from the power source.
  5. Turn the printer off and unplug it. Let it sit for 30 minutes to let the fuser cool off. Carefully remove the fuser; IT MAY STILL BE HOT USE CAUTION. Examine the fuser, if any damage is apparent the fuser may need to be replaced. If no damage is noted reinstall the fuser, plug the printer back in and power it up.
For More info Source... Hp Error Code 50 Service Errors 50 Fuser Printer Repair
Thanks,
HP Printer Support
Jun 26, 2014 | HP LaserJet Pro P1102
Getting an error code 50.9 "fuser error" went through the steps in the help screen and turned printer off/on. Help!
A 50.9 fuser error is one of the most common errors. If you get a 50.x error, you can try turning the power off and on and reseating the fuser but in almost all cases you will need to replace the fuser.
Do not forget to rate my answer
Lucas
Jul 07, 2011 | Office Equipment & Supplies
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board. http://printertechs.com/tech/error-codes/error-codes-50-59.php
Fuser Ref: http://computer.howstuffworks.com/laser-printer3.htm
May 05, 2011 | Computers & Internet
50.9 fuser error
Couldn't find any listing for a 50.9 error.
However, all the other 50.x errors, which are fuser errors want you to:-
1. turn printer off for at least 25 minutes, and then turn it on. If you still have the error
2. make sure that you are not using a surge protector. Plug directly into wall outlet.
3. Replace the fuser
Jan 10, 2011 | HP Color LaserJet 2600n Printer
Laserjet4 50 intervenire
X FUSER ERROR A fuser error has occurred. 1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Apr 07, 2010 | HP LaserJet 4 plus Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | HP LaserJet 4 plus Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
41 people viewed this question
k24674
