Question about Lexmark C510 Laser Printer
LEXMARK C510 SERVICE 931 PRINTHEAD ERROR WHEN YOU
LEXMARK C510 SERVICE 931 PRINTHEAD ERROR WHEN YOU SWITCH THE PRINTER ON IT COMES INSTANTLY TO SERVICE 931 PRINTHEAD ERROR
  • 412 Answers
SOURCE: 931.01 Printhead Service Error
there is a Printhead error - No first sync
Posted on Mar 09, 2009
  • 412 Answers
SOURCE: Lexmark C510 - 930 Printhead Error
93x Printhead Error
Each printhead error has its own error code number. The error codes and their respective meanings are listed below, together with some actions you can take to resolve the problem.
ALL printhead errors:
If this is the first time the error has occurred, try turning the printer off and on.
Let it sit turned off for at least 20 seconds before powering it back on.
If powering off and on the printer clears the error, please continue using the printer but watch it to see if any printhead errors return.
If your printer continues to display a Printhead Error message, make sure it is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer. This can trigger a printhead error even if the printer has worked on this surge device for months.
If the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
If the printer was recently serviced, make sure the correct parts were used. This is especially true if the parts replaced were either the printhead unit or the printer's engine/system board. It is in one of these two parts that the printer is detecting the problem. Note: If you are the person repairing such a printer, please be aware that parts from different, though similar, printer models may not be compatible with this printer. Also make sure to check the laser cable going from the printer's engine board to the printhead unit, as it reads that signal.
If the printer was not recently serviced before this error occurred and powering the printer off and on does not help, the printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
If the printer continues to post a 931 Printhead Error, it thinks there is an error in the signal going to the laser or the Hsync part of the printhead assembly.
If the printer continues to post a 932 Printhead Error, it thinks there is an Hsync error occurring in the printhead assembly.
If the printer continues to post a 933 Printhead Error, it thinks there is a failure in either the Hsync signal or with the mirror motor unit of the printhead.
If the printer continues to post a 934 Printhead Error, it thinks there is a "lock" failure with the mirror motor assembly within the printhead assembly.
If the printer continues to post a 935 Printhead Error, it thinks the mirror motor unit within the printhead unit cannot reach its operating speed.
If powering the printer off and on does not clear any of these errors and it is already connected directly to the wall, your printer may require service. It could have a defective printhead unit or there might be a problem with the engine board or one of the printhead cables. Note: If you are the person repairing such a printer, check all of the cables going from the printer's engine board to the printhead unit for any damage. Also check the continuity across these cables.
Source: Lexmark KnowledgeBase
SOURCE: Lexmark C510 Code error: 995 Service Engine Error
I had the same problem, I changed the photo conductor and it was ok.
I disassemble that part, all the bottom, I clean it with air, they were a lot of ink in, and after that, it works correctly.
Be careful not to touch the photo conductor with your finger, and avoid having strong light on it
Posted on Oct 03, 2008
don_farr
  • 1018 Answers
SOURCE: C510 printer displays "994 Service Engine Error". How do you addr
Here you go, courtsey of Lexmark's Knowlwdgebase.
Don
994 Service Engine Error on a Lexmark C510 ID: ENUS21233 If your printer is unable to move the photodeveloper belt to the correct position during printing, a 994 error will occur. However, it may simply be the case that the photodeveloper is either contaminated with excess toner or improperly installed. To test for and resolve this issue, please do the following:
  1. Power the printer off and remove the photodeveloper cartridge.
  2. Rotate the green metallic photodeveloper belt by manually turning the white drive gear on the bottom of the cartridge until the black positioning markers are visible.
  3. If necessary, carefully wipe any excess toner powder from the positioning markers using a soft, lint-free cloth or tissue.
  4. While the top cover of the printer is still open, inspect the sensor that is used to locate the positioning markers on the belt. CAUTION! The photodeveloper is very sensitive to light. Cover the green metallic surface of the photodeveloper with a piece of paper while it is outside the printer.
    • Refer to this image, this image, and this image to identify the location of the sensor.
    • Verify that the sensor has not come loose from its housing and that it is not contaminated with excess toner powder. If necessary, clean the sensor with a soft, lint-free cloth or tissue.
  5. Re-install the photodeveloper cartridge and power the printer back on.
  6. If the error remains, it is likely that a service call will be necessary to resolve this issue. Please contact Lexmark Technical Support, having first obtained the serial number of your printer. NOTE: If practicable, attempt to order another photodeveloper and replace it first to avoid the inconvenience of a potentially unnecessary service call.
Posted on Jun 22, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    The error 995 refers to a problem with the High Voltage Power Supply. This could mean three things one is that the Photodeveloper cartridge is damaged and needs to be replaced. The second one could be a problem with the High Volt Power Supply not providing enough charge to the Photodev. The third thing could be that the Engine Board is damaged causing the error in the display. You can try to reset the Photodev by pulling it out and the seating it back in the printer.
    Posted on Feb 01, 2010
    Error 931
    Solution What the error means
    A Printhead Error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
    NOTE: On the E250d(n) models, all service errors are signified by the flashing of all of the lights. To determine if this is a printhead error, quickly double-press the pattlnk_312007_2142-continuebuttonicon_e120_en_us.gif button to see the secondary code. If the !, pattlnk_3132007_1545-paperjamicon_e340_e342_en_us.gif, and pattlnk_3132007_1542-continuebuttonicon_e120_en_us.gif lights are the only ones blinking, a printhead or a motor failure is indicated. For more information on deciphering the error lights, click here (PDF file, 255KB).
    Clear the error
    Step Action 1 If this is the first time you have seen the error, turn the printer off. 2 Leave the printer powered off for 10 seconds or more before turning it back on. This gives the printer a chance to reset. 3
    Power the printer back on. If it goes to the Ready state, try printing again. If the error does not return, continue using the printer. 4
    If the printhead error returns when the printer is powered on or when you try to print again, follow the suggestions below.
    Check the power source the printer is plugged into
    If this is an intermittent error, you may want to check how the printer is plugged into the wall.
    Make sure the printer is plugged straight into the wall and not through a surge device or power strip. Please try this even if the printer previously worked correctly with this surge device. Power strips and uninterrupted power supplies can cause a low amperage problem, which can trigger a false printhead error.
    You may also want to try plugging the printer into a different wall outlet to see if the printhead error continues. This will eliminate the power source as a possible cause of the issue.
    If the error continues
    If the error does not clear, the printer will probably require service to correct the issue. Please contact Lexmark Technical Support or a local authorized servicer for assistance.
    When calling Lexmark Technical Support for service, please be prepared to describe the problem you are experiencing or the error message on the display. You will also need to provide your printer's model type and serial number. This information can be found on a label on the inside of the front cover of the printer.
    Please call from near the printer in case the technician asks you to perform a task involving the printer.
    Have a nice day and do not forget to rate please...!
    May 14, 2012 | Lexmark Optra S 1255 Laser Printer
    Printer lexmark C510," 956 service TCSD system board"
    With that " 956 service TCSD system board" error message, the only you can do is to replace the Rip/System Board. Hope I can assist you more on this.
    Apr 06, 2010 | Lexmark C510 Laser Printer
    What is 931 service error
    Hello my friend,this is printhead error,check connections at both ends of cable for corosion or oxidation,reconnect them.Also can be system board error.You can check the operation of
    the printhead shutter and clean the printhead window with a lint-freecloth folded over a cotton swab; do not use a bare swab and do not use any cleaning fluids or water on the printhead window if you see the defect on the photo conductor.Good luck:)
    Feb 03, 2010 | Lexmark T642 Laser Printer
    PRINT HEAD ERROR
    there are several different printhead errors 931 933 scanner motor died scanners bad. 932 934 935 are loose lock errors these can be caused by either the scanner or the engine board
    Nov 09, 2009 | Lexmark Optra T614 Laser Printer
    Lexmark C510 - Printer will not print
    Message:
    Invalid Engine Code
    What this message means:
    The printer engine code has not been programmed or is not valid.
    What you can do: [Not much]
    Call for service.
    See also: Calling for service
    Dec 04, 2008 | Lexmark C510 Laser Printer
    93x Printhead Error
    Jul 28, 2008 | Lexmark C510 Laser Printer
    May 06, 2008 | Lexmark C510 Laser Printer
    Lexmark C510 Laser Printer Logo
    431 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
