Question about Tissot T Touch Navigator 3000 T96.1.488.42 watch
I can not fix the display - analog time with the digital time, to be the same. Thank you!
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
Waveceptor 3310 Frozen "H-S ET"
You must set the digital time as well.Analog time (hands) follows digital time.At first press button A.If digital time is according to analog time ok.If not you have to follow "H SET" (hour setting) procedure.
May 01, 2014 | Casio Watches
Diesel watch dz7125 the digital display for TIME 2 has gone blank. Analog times (1,3 & 4) still run, and keep time.
probably needs a new battery there will be two batteries one for digital and one for analog,,
Aug 11, 2013 | Watches
The digital time display and the hands display don't match
You can try to so the synchronization to match the digital time and the analog hands.
here are the step by step procedure including visuals, click on the link.
I hope this will resolve your issue.
Thank you for choosing Fixya.
Mar 06, 2011 | Tissot T-Touch T33159851 Wrist Watch
I have a casio ediface 5033 80W-M10008 how do I set the analog time
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Best regards. Jewel
Sep 15, 2010 | Casio Edifice EFA109-7AV Wrist Watch
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Aug 21, 2010 | Casio Watches
Digital/analog watch... analog part doesn't run
A lot of times they hide a second battery for the analog display under the larger battery used to run the digital display. Also, the 2025 may not have a full charge.
Oct 17, 2009 | Watches
Cant se time Citizen 8988-q02047 HSB wristwatch
In the time mode, press the upper right button for 2 seconds and the time display will flash. Then press the same button untill the entire time will flash, or both hour and minutes flash at same time. When the hour and minutes flash at same time, this adjust mode is the adjusting of the analog left display (A1). Now, press the lower button for adjusting de hour shown at the digital display that shows the same hour at analog display. This method is to adjusting the 8982 that is the "father" of 8988. Like a Citizen collector, and don´t know any website that you can view the setting instruction of 8988, only the 8982 is disposable here: http://www.citizenwatch.com/downloads/techguides/8982.pdf
Nov 20, 2008 | Citizen Watches
10 year old alarm chronograph
good morning ! your anadigi chronograph 388 is veery easy to operate,just change the battery then short the reset button the fix the case back and set the time use the crown and the button to set the time calendar and the alarm !thank you ! god bless !....
Sep 01, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Tissot T Touch Navigator 3000 T96.1.488.42 watch Logo
133 people viewed this question
Top Tissot Watches Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Tissot Watch Expert? Answer questions, earn points and help others
