Question about Toshiba Satellite A135-S4527 Notebook
My laptop will fire up and if plugged into a desktop monitor or tv it works fine but I can't work from the laptop screen. It will light up for a moment and then go black. You can still see what is on the screen however it is very, very dark. I have one computer repair guy telling me it is the backlight bulb, another tells me I will have to replace the whole screen at a cost of about $300. What is the scoop?
  • 2,567 Answers
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Posted on Oct 06, 2010
  • slamarand Oct 06, 2010
    Ok thanks!
Hp probook 470 g1 starts fine but nothing on my screen, works on my tv but not laptop. only a week old have I done something
Right click on desktop -> select screen resolution. Select identify. If external monitor is number 2, select monitor number 1 (laptops monitor) and from dropdown menu select "extend these displays" or "duplicate these displays". Select apply, picture should be shown on both screens.
Apr 12, 2014 | HP Pavilion dv7-1130us laptop
Lenovo u260 screen black
Switch back to internal monitor in bios setup or do both internal and external monitor.
Feb 11, 2012 | Lenovo IdeaPad U260 Laptop Computer -...
HI I have used LG Flatron L1915S computer monitor. When I plug it into my laptop, it blinks showing the laptop desktop for less than a second then goes black. Other monitors works fine when I plug them...
There is often a function monitor key on the laptop, located near the F7 key area, the icon looks like a monitor on|off and is typically in blue. this key is to be used in combination with the Fn key to enable, disable the external monitor or enable both monitors or just the laptop. Press the key combination until your laptop panel lights up while the monitor is plugged in. Now check your extenal monitor refresh rate and resolution slider settings by right clicking on your desktop go to properties / video settings. (please note monitor settings are under advanced). You should see two monitors in there now. use "identify" button so you know which one to work with. on the external monitor settings, decrease (slide left the slider all the way). If you can set the monitor refresh to 60Htz. Lastly take a flashlight and check if you can see a shadow of your screen on the external monitor, if you can that means the backlight is not working and likely needs the inverter replaced. Hope that helps ! Cheers
Aug 30, 2010 | LG L1915S 19" LCD Monitor
Peripherals not working
Try plugging in a full size desktop monitor and reboot your computer. If the new monitor turns on its a problem with the LCD screen. If not, it is a problem with the main laptop which means a motherboard problem or a RAM problem. Try removing the RAM memory and reboot.
Aug 14, 2009 | Acer Aspire 5100 Notebook
Can't get external monitor to work properly
  1. Right-click on your desktop (anywhere there is not an icon).
  2. Click Properties.
  3. Click the Settings tab.
  4. You should see two monitors with a "1" & a "2."
  5. Right-click on "2" and click enable
  6. Your external monitor should come to life.
  7. You may want to make some adjustments with the resolution, and this option is on the same screen.
Apr 23, 2009 | Computers & Internet
Black screen after returning from florida
plug in > if charge light comes on and screen black proceed.... if no charge light comes on on laptop your charger's not working
plug into external monitor > if the external monitor works fine with laptop then your LCD is not working, you can look for the Function key (should be bottom left) and the monitor button (probably f7) and switch back and forth... this should tell you if the lcd works or not.
Apr 20, 2009 | Gateway MX6027 PC Notebook
Screen freaks out when external monitor connected
prombelms quite simple your 42 inch monitor has to many colors for the driver and it cann't work with it is incompatiable.....lala linda
Jan 06, 2009 | Acer Aspire 5100 Notebook
Setting up an external monitor to repalce a broken laptop monitor
Right click on the desktop
Click arrange icons by
Click show desktop icons
Dec 29, 2008 | Acer Aspire 3680 Laptop
Black striped down left hand side of display
Hi Danny, you haven't been very clear I will assume you pushed the auto configure on the monitor,
I would go into the menu on the monitor and reset the size of the screen if it has a setting for that 1024x768 should fix the problem
let me know what you find as I have never worked with a hp W19 monitor, if nothing else set the monitor to defaults again in the menu and that may get you back to having normal screens.
L8r
Nov 13, 2008 | HP w19 19" LCD Monitor
Connect laptop to cpu and use laptop as monitor
you can if your laptop has a fire wire plug in if so connect the 2 and if you have windows xp it will walk you through the process to get it started you have to set it up to work with a remote .
Dec 08, 2007 | Compaq Presario 5000 PC Desktop
Toshiba Satellite A135-S4527 Notebook Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
