Question about Relisys TL565 15" LCD Monitor
Please, would you mind to tell me were to buy a RELISYS monitor power supply cable. Model:TL540RU(S), Power: 12Vdc,4.17A 15"TFT LCD MONITOR FCC ID : PDU15
  • 11,361 Answers
How can i find a power cord to fit this monitor? The one I have is not getting power to it . It was tested by Best buy.
Most monitors have the same type power cord. You can order them cheap off of Amazon and eBay.
Heres on that should work: http://www.amazon.com/Cables-Go-03134-Universal-IEC320C13/dp/B00005113L/ref=sr_1_1?ie=UTF8&qid=1298845316&sr=8-1
Feb 27, 2011 | Envision EN 9110 19" Flat Panel LCD...
Where do i find a power plug for an older model
how about the plug size, normally, it comes with 2.0/2.5mm?? it looks like 15" lcd monitor and i think it is compatible with 12V 4.0~5.0A.
Mar 22, 2010 | Samsung SyncMaster 570 V (Ivory) 15 in....
We have a relysis 1520 15" TFT, sound ok but no sign of a picture
peterobin378, Gee, wiz, sounds as if you have internal power supply failure. Inverter circuit can't source voltage and current to light-up the "cold cathode-fluorescent-lamps" anymore. Inspect it for BAD swollen, leaky electrolytic filter capacitors and or poor soldering ( cold or frosty looking) solder joints of surface and through hole components. 12fixlouie
Jan 30, 2010 | Relisys RLT-1500 15" LCD Monitor
Samsung 540n TFT display comes for about 15 sec. with low breightness and then no display power remins on. This happens even when VGA cable is disconnected.
gptajipcf, When very strange things start to happen with LCD DISPLAYS the first place a Technician will investigate would be the monitors "switch-mode-power-supply" and it's "inverter" supply that supplies 800-1200vac to light up the "cold-cathode-fluorescent-lamps" that provide "WHITE LIGHT" for the LCD panel. I recomend a visit to YOUTUBE so you can find and view some video clips of "LCD monitor disassembly" and "LCD monitor repair" and find out if you think you would be able to repair your monitor or have someone else do the work for you. You didn't tell us if the unit is still covered by warranty??? Check with Samsung about doing a CASH+OLD for a Refurbished same model unit. Also visit ccl-la.com/badcaps.htm for more info on what may cause your monitor to do stupid stuff as you described above. I hope this info was of some help to you. If so please rate this response on fixya. 12fixlouie Bye for now.
Oct 26, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
All of a sudden there is no picture on my relisys 15" tft monitor, sound and channel change work, please helpnessa, thanks va
The fault is likely the back-light. The fault could be the inverter board that supplies high voltage to the CCFL lamp or the CCFL lamp. The CCFL lamp is a mini fluro tube.
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
Oct 20, 2009 | Relisys RLT1720 17" LCD Monitor
I require an adapter for my Relisys TL775 LCD Monitor.
Belkin makes an adaptor for nearly everything regardless of the country. You must specify which connector you have by name and what you wish to connect to for further help. Here is a link to a UK mag review which spells those designators out for you: http://www.pcpro.co.uk/reviews/44632/relisys-tl775.html
If you need further advice please repost. Steve
Nov 30, 2008 | Relisys TL775 17" LCD Monitor
RLT1520TV-RV(S)
HI Maxine you want adapter model LAD6019AB5 input 100-240 VAC 1.5A output 12VDC 5A ROGER T.
Apr 07, 2008 | Relisys RLT-1500 15" LCD Monitor
Cannot turn off Auto Adjustment... message.
i has same problem and I have no idea how to disable. :(
Hope someone know how to help us out!
Dec 27, 2007 | Relisys TL565 15" LCD Monitor
Relisys TL565 15" LCD Monitor Logo
95 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
