Question about Canon Office Equipment & Supplies
How can i remove department ID and password for canon iR3530 copier
2 Suggested Answers
SOURCE: i forgot password id device canon ir 2022 copier
you can go to service mode by (pressing additional function (*) then press 2 then press 8 then press additional function again) then move the arrow to CLEAR menu and select PWD.
Some small machine you can go to service mode by hitting ( * and #).
Posted on Aug 04, 2011
Haw to find the all night power suply in ir3530
There is No such power supply called "all night power supply". Have you tried to adjust the display contrast on the control panel????/
Jan 13, 2013 | Canon IMAGERUNNER 3530 Copier
Canon IR c6800 department password
You can just reset the password if you dont have it by doing this,
press additional functions
2 + 8 simultaneously
copier
clear
right arrow button
PWD-CLR
ok
turn off then on the power switch on the right hand side of the copier.
Dec 10, 2010 | Canon imageRUNNER C6800 Copier
Today I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution...
oday I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution for disable or reset the same.
Oct 23, 2010 | Canon iR 2022 Printer
I would like to Reset/Retrieve Password for Copier Setup Canon, ImageRunner canon ir 2318
If you know the password, then under user mode, i think system sett., must be option for department id management where you can change passwords.
If you dont have pass, you can do clear all under service mode ( * 2 8 * ) if canon changed service mode, like on some series, you can try MENU and #.
Hope that helped
Jun 29, 2010 | Canon imageRUNNER 2200
Startuo ask for Depart ID and password
You need to turn dept id off but to do this you'll need to clear the system password. You need the service mdode to do this. Press the head key once (the key with a head and star inside) then the 2+8 keys at the same time, then the head key again. This will get you into service mode. Now select 'COPIER' then 'FUNCTION' then 'CLEAR' now look for the option the reads 'PSW-CLR' select it and press OK. Now turn off the machine by the control panel and then the power switch. Now turn the machine back on and you should be ok.
Jun 17, 2009 | Canon Office Equipment & Supplies
Admin password for Canon ir2270 MFC
JUST HAD THE SAME PROBLEM. THE DEFAULT ADMINISTRATOR PASSWORD IS "BLANK" LEAVE THE PASSWORD FIELD EMPTY AND PRESS ENTER
Mar 17, 2009 | Canon Office Equipment & Supplies
Imagerunner 330s id
remove all the ids you stored in the machine. even one id is left means it will ask for p/w.
Feb 18, 2009 | Canon ImageRUNNER 330s Copier
IR5000 Service Mode
you may need to clear the passwords. what happens when you hit the Additional Functions button?
Mar 19, 2008 | Canon imageRUNNER 5000 Copier
Startup Password
Press *, 2&8 (at same time), then * again to enter service mode. Select FUNCTION from the icons along the top of the screen. Press Clear and find PWD-CLR. Press PWD-CLR and press ok. Press RESET (yellow button) twice to exit service mode. Password should be removed.
Jun 14, 2007 | Canon CLC 1150 Color Copier
297 people viewed this question
old marine
old marine
