Question about Morphy Richards Jet Stream 42271 Iron
I have a Morphy richards Jet steam iron I bought second hand - has no manual and now I need to clean the iron but without a manual I cannot do so. Althouth it heats up, the steam will not come. Pls help.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Morphy Richards Master
  • 102,366 Answers
You can download the manual at
http://www.morphyrichards.co.uk/Downloads/InstructionBooklets/IB42271.PDF
Posted on Jun 15, 2011
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Jun 02, 2014 | Morphy Richards Jet Stream 42271 Iron
Water leaking from soleplate.....
Your Morphy Richards Jet Stream 42271 Iron is developing a leak. If the leak becomes worse, you may have to replace the iron.
Mar 05, 2018 | Morphy Richards Jet Stream 42271 Iron
Descale
Soak and/or run vinegar or CLR through it. They also make a steam iron cleaner.
May 11, 2013 | Morphy Richards Jet Stream 42271 Iron
Can't get my Morphy Richards steam generator off of standby
do this and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water
Sep 24, 2012 | Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
My Morphy Richards Jetstream is about 5 or 6 years old & works fine except that when I first use the steam I get brown water marks on items. This means I have to wash them again. What can I do to solve...
Try cleaning the inside of the water holder it might just be calcium built up, use white vinegar to clear it and you'll prolly be fine. Put vinegar where you usually put the water and heat the iron up and steam the vinegar through the iron then put water, try distilled water to save this problem from happening again or try filtered water.
Jun 08, 2011 | Morphy Richards Jet Stream 42271 Iron
Morphy Richards Jet Stream 42271 Iron Logo
1,367 people viewed this question
Top Morphy Richards Irons Experts
Mack Baxter
ray gallant
Are you a Morphy Richards Iron Expert? Answer questions, earn points and help others
