Linksys KVM 4-Port CPU Switch  KVM Switch
Problem for Linksys KVM 4-Port CPU Switch (843734000836) KVM Switch
Trying to connect share printer w/Vista
By jrm0726 on May 28, 2008
I have a desktop & laptop w/Vista (both less than 6 mths old). My printer works with each individually when connected directly to the printer. But I can't print from my laptop through the network. I have a linksys router on ethernet connection. I have tried EVERYTHING & I'm about to throw it all out the window. Please help!!!
Solution #1
posted on Mar 17, 2009
Somewhat Helpful)
cmccarty
Rank: Wiz
Rating: 84%, 22 votes
If you connect the printer to the desktop computer and enable file and printer sharing on that computer. You will then need to go into printers and faxes and share your printer. Then go to the laptop and browse the network so you are looking at the desktop computer. You should see a folder that says printers. Open the printers folder and you should see the printer you just shared. Double click on it to install the shared printer on your laptop.
Now when you print from the laptop, you will print to the shared printer that you just installed (you may have to select it from the printer list). That will send the print job through the network to the desktop and the desktop will send it to the printer (the desktop will need to be turned on for you to be able to print).
If you don't want to have to leave your destop turned on just so you can print, you should look at a print server for your printer. That will connect the printer straight to the network. Then both computers will print to the printer over the network.
Was this helpful?
Yes
No
Popular Solutions for Linksys KVM 4-Port CPU Switch
Questions and Unsolved Problems for Linksys KVM 4-Port CPU Switch
Do you recommend Linksys KVM 4-Port CPU Switch (843734000836) KVM Switch?
Answer
Answer
what code should i put in when asked for the new starview hd model ????
Answer
I have a television KVM162OU and remote control 694 but cannot manage to tune my television to get... (More)
Answer
Using one Belkin 16-port KVM to switch between Windows, Linux and Unix. Windows works fine, Linux... (More)
Answer
wondering how much water used per load
Answer
I have used these before but for some reason I can't toggle back and forthe using the Scroll Lock. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top KVM Switches Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
