Question about Motorola Mobility Rival A455 Cell Phone
My Rival took a ride through the washing machine. After letting is sit for several months it will now turn on. However, it seems to be stuck in a continual reboot loop. It powers up showing the Verizon logo, briefly goes blank and then shows the Verizon logo again. Any thoughts or suggestions?
    Sergeant:
    Champion:
  • 218 Answers
Yes my friend open your phone clean all the parts by cleaning with thinner by using tooth brush .this because some water may have logged those parts.try your luck.if not get cleaned by your near by service centre.
Posted on Oct 06, 2010
Rtw4340sq0
Sounds like bearings are shot!!!call warranty company, let them sort it,,,it's normally quite expensive
Jun 17, 2013 | Washing Machines
Pressure plate and clutch plate is stuck together
You might be able to take the starter out to access the flywheel and use a pry bar to break them apart. You could also have a failed slave or master cyl.
Dec 07, 2012 | 1988 Toyota Pickup
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Model WTW6600SBO: Machine is stuck, won't spin
I'm having the exact same problem...did you ever find a solution?
Jun 16, 2010 | Whirlpool WTW6600SW Top Load
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
I have the Rival electric skillet [S16RB]. The center is approximately 1/8 inch higher in the middle of the pan which lets all the greace run from the food i am frying. The conter on which it is sitting on...
Seems they are all the same and that must be the design as mine does the same thing.
If your product is less than 1 yr old and you have your receipt, (you can fax, email or snail mail it ) they will send you another. Or if you dont they "might" ask you to cut the cord off and send it in, only to wait a couple of months for your replacement.
You can contact them at http://www.rivalproducts.com/help.aspx?helpNav=3 or 800-323-9515
Oct 23, 2008 | Rival S16RB Electric Skillet
Fisher Paykel GWL10US won't spin
hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
Oct 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing machine only pumps the water out sometimes.
It sounds like the motor is heating up and when it cool its able to turn on for a little longer. Replace the motor.
May 26, 2008 | Tecnik TKL9260 Front Load Washer
Motorola Mobility Rival A455  Cell Phone Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
