Question about Kohler K-3497 Cimarron Comfort Height Two-Piece Round Front Toilet, Left-Ha
When flushed, not enough water coming from bowl rim holes to wash waste off sides of bowl. Have checked holes around top rim, none are plugged. This has been a problem since purchased one year ago.
    Sergeant:
  • 268 Answers
Its simple. Check to see if you installed toliet right by removing top of tank and holding handle all the way down. Did it flush from all rim holes? If not, then u will need to get a garden hose with a sprayer to increase pressure and shot high volocity water at rim holes to unblock it. Remember the very front on newer blows do not have holes its a pee shield. Also try doing these other things adjust screw inside tank to make sure the bowl has enough water in it to do a good job. Check the rubber tube going into the hollow pipe and make sure it is going fully inside the plastic pipe that is sticking out of the top of the water in the tank. Also you need to have enough water in tank to allow it to flush good. To increase tank water levels then just unscrew the big plastic ball (or just bend wire to allow more water or bend to allow less water) at top of water in tank. Also increase (max) water pressure at wall to allow it to work at its best. If you have hard water it can cause problems but you say it happened even new, so, you do not have to go in that direction.
Posted on Oct 06, 2010
Why doesn't the waste go all the way down? It takes several flushes.
Welcome to our new world of water conservation. If you have a toilet that isn't newer....you have something in your trap weir. Or your flapper is malfunctioning. Or your float valve isn't filling your tank correctly. Or your bowl scouring ports could be clogged. There are sooo many things that could cause this....
.New toilets do this because their design to use less water has reached the point of no-longer working to clear the bowl contents. Plain and simple. It has became the norm to flush once for #1's and flush (how ever many it takes to flush all waste) for #2's.
Back to old styles...You can remove the tank top and inspect the water level in the tank(should be about a 1/2" below overflow tube when full), inspect the flapper(flush the toilet and see if your flapper is staying up long enough to allow enough water to enter the bowl to cause a syphon action that ends with a suction sound and complete emptying of the water from the bowl), flush your toilet and look in the bowl to see if the water spraying from your rim is adequately dispensing water to scour the sides of the bowl, and also look at the jet that shoots water from the bottom of the bowl...aimed toward the outlet portion of the very bottom of the interior bowl. This jet is what starts the syphon action that empties your bowl. If you have something stuck in your trap weir....you probably need to call your Plumber to auger the object out or break it down to a size that will pass into the sewer.
The small ports that spray your sides can be cleared with a 3/16" stiff nylon brush...the jet down below can be cleared with a 1" stiff nylon brush. Flapper malfunction is repaired by replacing the flapper. Incorrect water level in the tank can be fixed by adjusting the valve float. but chances are that if it is all of a sudden malfunctioning...it probably needs to be replaced...good luck and always know how to turn your water off before starting work on your plumbing.
Be gentle with the parts inside your toilet tank. Using a calcium remover when clearing bowl inner ports and jets will help tremendously....but be certain to read the container and follow all handling/use instructions you read. Be careful.....Nick
Mar 06, 2015 | Plumbing
Why wont my have a cimarron k3489 toilet fully flush? the water empties from the tank but the water from the bowl does not go down.
That's an interesting one! Does the flush valve close properly so the tank can refill? Does the float valve allow the tank to refill fully, to near the top of the overflow? That can be adjusted, if it doesn't.
Check fhe flush valve - you may have an obstruction under it. Also check the water port from the bowl side - feel up inside the port for obstructions or buildup of hard water deposits.
WASH YOUR HANDS THOROUGHLY afterwards.
Jul 29, 2014 | Kohler K-3489 Cimarron Comfort Height...
I have 5 kohler pressure assist toilets with flushmate 503 series tanks in my home. Several of my bowls have minimal to no bowl rinse. My water pressure is more than adequate. I recently changed a...
There are two holes in the top of the bowl where the tank attaches. As you indicate, one hole delivers water to the jet at the inlet to trap passageway, and another smaller hole to direct water to the rim.
I have seen in some cases the gasket that seals the tank to the bowl block the smaller rim-fed hole. All you need to do is knotch the gasket where the hole is located and re-install the gasket so the knotch is located over the hole. If you have any other questions please call the 800 phone number on top of the Flushmate.
May 19, 2011 | Kohler Home
I installed a new complete Fluidmaster and filled it up with water but when flushing water comes out under the tank not under the toilet though.
probably needs a "doughnut" tank washer under tank..or try tightening the tank bolt..fluid master comes with a little rubber hose that goes to overflow tube
Nov 25, 2010 | Fluidmaster Plumbing
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
Tiolet not flushing right. Water not coming down the side of the bowl when flushing and 90 percent of the water is gone from the bowl.
1- Check ports out under rim all round bowl.
2-Check tank fill level for required amount to with in 5/8" to top of over flow tube.
3-Make sure 1/4" fill tube is connected to over flow tube. From fill valve to overflow tube.
Below is a few details to go by I hope will be helpful for you to take care of this problem.
Under the rim of the bowl check the ports and make sure they are not stopped up. You can open them up with nail or pin to clean out ports.
Next check tank level and make sure the fill valve has a line run from it to top of the overflow tube. This line allows water to goe to bowl and tank to fill required amount needed.
Water in tank should be within 5/8" to top of over flow tube.
Jun 22, 2010 | Pegasus Technologies Two-Piece Round...
Bowel cleaning
Check the ports under the rim and make sure they are not clogged. To do this you can use a nail or pin to clean them out.
Right under the rim of the bowl are these ports that allow the water to flow into bowl in a turning motion to aid in flushing and cleaning wall's of the bowl.
Inside the tank check the fill tube and make sure it is connected from the fill valve to the over flow tube. Also check the fill level in the tank and make sure water is up to the line on the fill tube about 5/8" from top of tube.
Jun 06, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
The flush does not seem to be strong enough. Waste was stopped up. Is there anything I can do to improve volume elimination?
FIRST CHECK THE WATER LEVEL INSIDE THE TANK. MAKE SURE IT IS INLINE WITH THE MARK INSIDE THE TANK. SECOND, GET A TOILET BRUSH AND SCOUR UNDER THE TOILET RIM AND DOWN THRU THE BOWL AS FAR AS POSSIBLE. USE " Comet Bathroom Cleaner", "Soft Scrub Original", "Bon Ami". BY ENSURING U HAVE THE CORRECT WATER LEVEL AND THE HOLES UNDER THE RIM AND THE BOWL IS CLEAN, THE FLUSH SHOULD IMPROVE. DON'T FORGET TO MAKE SURE THE FLAPPER VAVLE OPENS AS IT SHOULD TO ALLOW WATER TO FLOW INTO THE BOWL EFFICIENTLY.
Dec 14, 2009 | Kohler Home
When flushed, not enough water flow to empty sides and waste
make sure water level is sat at factory settings. there should be a black line that reads WATER LEVEL. If this is not the problem. then you have calci buildup. get a gal. of muratic acid,plunge all water out of toilet bowl. then dump in at least 1/2 gal. let set over nite. with water turned off. get up turn on water then flush. You mite have to do it twrice. hope this helps you.... duane.
Sep 28, 2009 | Kohler Barrington Pressure Lite Elongated...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler K-3497 Cimarron Comfort Height Two-Piece Round Front Toilet, Left-Ha Logo
213 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
