Question about Acer Value AL1703SM 17" LCD Monitor
No green light on monitor
Hi my Acer AL1703SM is not turning ON, please help
  • Tyler Bateman May 11, 2010
    have you checked your cord
    Sergeant:
  • 458 Answers
If it is plugged up and not working then it is dead. Check the power source.
Posted on May 29, 2008
Green lines in left side of screen.In paralel and horizontal position
If the monitor does the same thing or similar on another computer its the monitor or vga lead at fault
Check first, the security of the connections from the computer to the monitor, these need to be tight to avoid loose connections and therefore signal loss, id these are ok, check the condition of the vga cable, look for splits cracks and bent pins on the end of the lead, check also the socket condition of the monitor, if any pins on the lead are damaged, discard and replace the lead
If the monitor signal is ok on another computer, check the graphics card / connection to graphics port on the computer, could be this is faulty.
Now check the monitor by resetting to factory settings and pressing the degauss button, check also that there are no magnetic devices like speakers near the monitor.
After those checks it still occurs, the monitor is failing and will need replaced
Jul 28, 2011 | Acer Value AL1703SM 17" LCD Monitor
The monitor itself is black, and the power light is changing color from green to yellow to orange and flickering.
Hi there!
Changing the monitor light from green to yellow/orange/amber means that the monitor is in power saving mode. Make sure that the video signal cable is properly connected to the back of the monitor as well as to the computer.
Hope this helps.
Apr 23, 2011 | Acer H233H bmid Monitor
Acer 1707a blingking lights
Most likely a power supply problem. you need to find a service manual, or take your unit to an Acer, recommended, service center, ask for a "Quote" for the repair, before proceeding, as sometimes cost of repair is nearly as much, as a new one.
Apr 27, 2010 | Acer Value AL1703SM 17" LCD Monitor
Acer AL2216W's green light goes off completely when the computer is turned on. When I turn on the computer and monitor, there is green light on on/off button while an irritating Acer logo is showing up....
You may have failure in the power supply due to bad caps, bad inverter circuits such as shorted transistors, transformers, bad lamps. You need to open it up and make some measurement, see example of failed ACER monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 13, 2010 | Acer AL2216W LCD Monitor
The color on my monitor is changing by itself... going blue yesterday and red today? whats up?
Sounds like either your monitor is about to break or that there is something wrong with the connection between your computer and your monitor (something wrong in the cable). Next time that happens, try to move the cable connecting your computer with the monitor. If it fixes it, you better go buy a new cable.
Dec 03, 2009 | Acer Value AL1703SM 17" LCD Monitor
My AL1703 sm monitor will not power on.
that means the power cord is faulty, the monitor does no send message to the power cord rather the power cord sends message to the monitor so its the power cord that's bad expecially if its an adaptor, thanks
Jul 17, 2009 | Acer Value AL1703SM 17" LCD Monitor
My monitor is new .. the screen stays black and the power button flashes green ... how do i fix this ????
Hi!
I have acer al1716 LCD and whan the computer is turn on, the lcd led turn green but the lcd is showing black, what i can do?
thank you!
Apr 16, 2009 | Acer AL1716 17" LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Won't Turn On
Hi
If the green light doesnt turn on, check if the wall outlet is workign properly.
Also pls check with another moitor power cable.
If the above steps dont work, then the monitor needs to be serviced.
Jan 14, 2008 | Acer AL1912 19" LCD Monitor
Acer Value AL1703SM 17" LCD Monitor Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
