Question about GN Netcom GN Jabra BT620s Bluetooth Stereo Headset - Wireless, Cable - Stereo Output - Behind-the-neck Headset
Jabra bt620s power on
My fully charged Jabra BT620S just wont power on? Was working fine up until i tried to charge via my pc using an usb? Is there a reset or factory default option?
thanks
  • parsis Jan 18, 2009
    hey I think I have the same Problem with mine.....just seems dead only thing working is the red light on the right hand side as I charge it, and dose not detect on my PC via USB :(
My jlab (same set) does the same thing...any fix for it?
It works only via USB to PC because that is not only the way to transfer MP3 files from your PC to the player/headphones, but one way to charge the player's battery. You can also charge the player with the USB cable by plugging it in a USB wall charger. So let it fully charge in the PC or the wall charger and then take it with you while you walk, work out, etc. There is nothing wrong with your player (maybe the fact that there is no indicator when it is charging and when it is fully charged ??).
Dec 28, 2014 | JLab Audio GO Waterproof MP3 Headphones...
I have got a Jabra BT620s and connected it with usb to Windows 7 64 bit pc. The drivers automaticly were installed and ready to use. But there is no sound trough the headset, only trough the speakers. When...
Does your computer have built in bluetooth? if yes,make sure you press and hold the stereo bluetooth till its steady blue,,not blinking blue. then on your pc, go the bluetooth section in control panel and search for devices. then you should see the Jabra Audio device.click on it to connect to the Jabra and use the passcode 0000. After it connects, the steady blue should now be blinking blue. Then go to control panel, sound and you should see the Jabra there.Right click on it and click on set as default device. Now play any song and see if you still have it playing in your speakers.Let me know if it works.I have the same Jabra and its really works great.Especially when im working out and dont want no wires around me
May 06, 2011 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
Jabra bT260s Pairing problem...
You may need to change your output sound device. The method may vary depending on your software and hardware, but go to Start -> Control Panel -> Sound (I think. Doing this from memory, so might be slightly off). There should be a Devices or Output tab. Change that to your bluetooth headset. You will probably need to restart WMP before you hear music, too.
Jan 18, 2009 | Jabra BT620s Consumer Headphones
How to pair Jabra BT620s Bluetooth headphone with HP Laptop?
Hi
• At your computer Right click on the Bluetooth icon on the task bar.
• Select “Explore my Bluetooth places”.
• Click on “View devices in range” to see all available devices.
• Right click on the Jabra BT620s and select “Pair device”.
• Enter the four digit passkey: 0000 (4 zeros).
• Right click on the Jabra BT620s and select “connect”.
• The connection will be established automatically, otherwise if the Jabra BT620s is ringing,
press the answer/end button to confirm the connection.
Good Luck
Aug 10, 2008 | Computers & Internet
HTC Mogul does not accept passcode 0000 for Jabra Bt 620
try 00000 (five zero's) or 1234 or 12345; the first should work the others will work as well
Jul 27, 2008 | GN Netcom GN Jabra BT620s Bluetooth Stereo...
Stiletto Only charges via usb (no wall or dock power)
return it is you can. Its not suppoused to "charge" via USB, it is only ment to be self-sustaining not charge. Contact Sirius for Warranty Return info.
Feb 11, 2008 | Sirius STILETTO 100 MP3 Player
My M1 from Sayno and my jabra b260s
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Dec 31, 2007 | GN Netcom GN Jabra BT620s Bluetooth Stereo...
Pairing problem
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 23, 2007 | Radio Communications
Pairing with my Sony Ericsson w810i's MP3 player
hi stefan,
sorry to let you know but sony w180 does not suort an A2DP profile,
which is necessary to listen music wirelessly. so u'll have to change ur handset if
u want to listen to music via ur bluetooth headset.!!
good luck!
Dec 11, 2007 | GN Netcom GN Jabra BT620s Bluetooth Stereo...
Open Questions:
GN Netcom GN Jabra BT620s Bluetooth Stereo Headset - Wireless, Cable - Stereo Output - Behind-the-neck Headset Logo
144 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
