Question about Promise SATA300 TX2plus (SATA300TX2PLUS5PK) Serial ATA Controller
I am trying to install win xp with sp2 on my laptop. i was using vista on it before . it show this error message; A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again follow these steps: Check for viruses on your computer. Remove any newly installed hard drives or hard drive controllers. Check your hard drive to make sure it is properly configured and terminated. Run CHKDSK /F to check for hard drive corruption, and then restart your computer. Technical informaiton: *** STOP: 0X0000007B (0XF78BE524, 0XC0000034, 0X00000000, 0X00000000)"
  • 7,733 Answers
If you want both OS you need to do a partition on the HD to proceed.IThat what i can figure from your quest.But if you just want XP just do a clean installation of it.
Perform a clean install of Windows XPA clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base:313348  (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup programTo perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
If you have successfully installed Windows XP, you are finished. If these steps did not help you install Windows XP, go to the "Next Steps" section.
Posted on Oct 06, 2010
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
Win xp sp2 & sp3
WinXP can go directly to sp3 which can use IE8. Microsoft sells sp3 for $4.95 plus postage.
Apr 17, 2012 | Computers & Internet
Error Message 103
I think it maybe because you haven't installed the "Driver" either at all, or properly. Uninstall any/all software. Reboot, DO NOT plug in unit. now, re-install the Software and Driver. Reboot, NOW plug in the unit, it should now be detected, and work.
You don't say what OS you are using? If Vista or Win 7, try installing as Administrator and also set Compatibility Mode for XP SP2 and run the main .exe as Administrator too.
Feb 12, 2010 | Digital Blue QX5 Microscope
Receiving error message: WlanMon.exe - Entry
Try a reinstall of the software sounds like that wlanapi.dll isn't being "Registered" If installing on Vista or Win 7 use Admin mode and try Compatabilty Mode for XP SP2.
Feb 03, 2010 | Blitzz Technology (BWA611) Router
Yahoo messenger 9 CONFERENCE: Audio Compression Err with Vista OS
u intall win xp sp2 never install vista xp then this error not show because vista xp not install audio driver properly plzzzz intalll sp2 win xp thx
Mar 16, 2009 | Logitech 250 Headset
I can't install windows xp
If you are going to triple boot your computer you need to install XP first, then Vista this will edit the Master Boot Arecord as needed.
Mar 10, 2009 | Acer Aspire 4315 Notebook
WINDOWS XP SERVICE PACK 2
try to change HDD to IDE from ACHI in BIOS, then you can normal install xp. if there are no this option in BIOS, then you have to make a installation CD included ICH 7M driver to install.
Feb 17, 2009 | Computers & Internet
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Non detection of hard disk in dell laptop while installation of win xp sp2
I haven't heard of not being able to delete a partition before. You could go to the manufacturer of the hard drives website and find the software to do a low level format or you could download a linux distribution and use the installer to remove the ESIA partition.
I would need to know the model of hard drive and laptop if you need any further assistance.
Sep 08, 2008 | Computers & Internet
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
Promise SATA300 TX2plus (SATA300TX2PLUS5PK) Serial ATA Controller Logo
283 people viewed this question
Top Promise Computers & Internet Experts
Gareth Cockram
Gareth Cockram
C. David Graves
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
