Question about Cisco ASA 5520 Firewall
I habe problems with an asa 5540, all the leds turn on at the same time and do not boot, not even send any information. where could be the problem regoard
Organe color showing in Active + status led on Cisco ASA 5515
Hi the documentation lists it in detail if you donot have the docs then access the same on Cisco web site it is free
Feb 24, 2009 | Cisco ASA 5505 Firewall
Cannot turn on my adp1
Seems like you need to send your phone to Dr Cell Phone for Diagnostics. They can do Cell Phone Diagnostics and tell you exact problem with your phone. Their diagnostic service is only $24.99. For more information visit www.drcellphone.com
Feb 12, 2009 | HTC G1
Replaced lamp, now no fan & hot plistic smell, (of course)
This model monitors the fans, should one not work the set should not even turn the lamp on, leaving only the timer LED flashing. Recheck your work but you have had other problems to begin with. Be sure the covers are reinstalled properly. Are you getting a Temp LED that is lighting? If so then the Temp sensor needs to be replaced.
Dec 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
CIsco ASA 5510 fire wall problem
Hi Thangaraj_j,
Can you provide the topology of your setup? Can you provide also the following:
- running configuration of the ASA
- ip address of the server (what kind of server is this? what tcp/udp port does it use)
- show xlate
- show con
- show log
Just a quick try, have you tried clearing the translation and the arp table?
commands to do it:
clear xlate
clear arp
clear local
Let me know and if it still doesn't work, try to ping the server from the pc clients and see if ping does work. (you need to allow icmp to pass thru in case you are denying it for testing purposes) Just send me the additional information given above.
Regards,
ex_ocsic_cat
Nov 01, 2008 | Cisco ASA 5510 Anti-X Edition...
Alert light in f4 is apearing
I too had this problem. I had owned the F4s from new but only lightly used it. A single shot only then the red light flashing. Nothing I tried corrected this inc changing batteries, resetting DX / ASA setting etc. Even opening the camera back to ensure the film was feeding (one cause) and finally running an old film through on the fastest drive speed. Eventually I had to take the camera to a Nikon repair agent who charged me £230. On the first shot when I got it back the same happened. Naturally it went straight back and they kept it for another 3 weeks. I now have it back and it's OK (so far). I still did not get a satisfactory answer to what was wrong but I was told the top and bottom drives had been rebuilt. Sorry this is not a quick fix but I don't think there is one. to hThere is nothing in any of the books or manuals to help or even mention it. best wishes Brian
Aug 13, 2008 | Nikon F4s 35mm SLR Camera
Boot-failure
I habe exactly the same problem. I habe the P45 Neo3 Board with E8400 CPU and 4GB Dominator RAM(1066MHz). No signal aber reboot. A Bios-Reset helps vor a Moment, but after Restart, i habe no signal.
Jun 16, 2008 | Intel Motherboard
Problem in installing the asdm image ASA 5520 ver 7.1
I had this same issue on my ASA 5520.
1. Copy the config and IOS image to a tftp server.
2. Format flash (disk0)
3. set rommon server, ip addy, and file settings.
4. tftpdnld
5. Once the system has booted to the image copy the asa image file, asdm image file, and config to flash
6. configure asdm image default location and reload
Feb 27, 2008 | Cisco ASA 5520 Firewall
Cisco ASA 5520 Firewall Logo
203 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
