Question about Canon T70 35mm SLR Camera
Shutter sticking open
When I take a picture the viewfinder stays black until I jiggle the camera. Then there is a click and the viewfinder is open again. I have replaced the batteries and the film. I think the lens I have is a bit loose. But when I take the lens off and check I notice that the mirror gets stuck, but that was after I had my finger in the way of the shutter.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey jimicricket,
The mirror is what reflects what the lens is seeing up to the viewfinder, and if it is sticking in the up position that is why you can't see anything sometimes thru the viewfinder. I would have the camera looked at by an authorized service technician, and it's possible that it just needs a good cleaning.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 28, 2008
The viewfinder screen is completely black. no image whatsoever. it seems like the camera is functioning everything works from what i gather
Since it's a film camera, there are a couple of things to check:
1. You have left the lens cap on.
2. If this is a single lens reflex camera, take the lens off and make sure that the mirror isn't stuck in the "up" position. If it is, GENTLY pull it down until it stays down. At this point, your shutter may be open. Try cocking the shutter again, fire off a test shot, and see if the mirror sticks in the up position. If it does, you probably need to replace the mirror bumper foam - age can make foam deteriorate into a gooey, tar-like substance that can make the mirror stick in the up position.
3. Does the camera have a T (for Time) setting on the shutter speed dial? If so, turn it off the Time setting and set it to a manual shutter speed such as 1/60 - or whatever your 'X' synch speed is.
4. Your batteries died in mid-exposure. Replace the batteries. You may have enough juice in them to show the viewfinder display, but not enough to finish the exposure and close the shutter.
Nov 16, 2017 | Pentax MZ-60 QD 35mm SLR Camera
My camera (digital rebel xsi) is not taking pictures. It sounds as if it taking the picture, but I think the shutter curtain isn't opening. All the pictures I take come out black. Is there a solution for...
Sounds like either the shutter or maybe even the mirror. Are you able to see a picture through the viewfinder? If you can find a very clean area, try taking a long exposure (30 seconds) and and see if you can see the mirror through the lens. If you can see through the viewfinder, and the long exposure is still black, then I fear you are correct.
Mar 21, 2011 | Canon EOS Rebel XSi Digital Camera
The display is black through the viewfinder and the screen. The menu displays and pictures taken previously on the memory card can be viewed, but in camera mode, the screen is black and pictures taken are...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Sep 05, 2010 | Canon PowerShot S2 IS Digital Camera
When camera is turned on no picture appears in the viewfinder or on the LCD screen, it remains black. The batteries are new. I can access the menu, change settings. Everything works but there is no image...
Sep 04, 2010 | Canon PowerShot S2 IS Digital Camera
Shutter won't open/blaack when you look through lens
Your shutter may be stuck open... this will give the appearance of the shutter not opening as well as no image when you look through the viewfinder.
Open the back of the camera, as if you were replacing the film, and look to see if the shutter is open. If it is, you can probably see light coming through the lens when looking from the back of the camera.
If this is the case, you will need to find out why the shutter is stuck open.
Some cameras use a battery to activate the shutter, some cameras have a "bulb" setting that keeps the shutter open for long exposures.
Whatever you do, do NOT force the shutter... I might jiggle it a little bit to see if it will close, but I wouldn't recommend more than a slight jiggle.
While you have camera open, inspect the mirror. If the shutter is closed but the mirror is stuck "up" (to allow light to reach the shutter/firm), there is a chance that you would not be able to activate the shutter.
Aug 31, 2010 | Pentax Program Plus 35mm SLR Camera
Shutter appears to be stuck closed.
Theirs oil on the shutter blades causing it to stay closed, Thats why you can't see though the lens or the viewfinder also, This comes from the grease from the zoom assy, It's a major job to fix it, Has to be fixed by a repair shop
Jun 04, 2010 | Canon PowerShot S3 IS Digital Camera
Camera shows no image through the viewfinder or on the lcd screen.pressing shutter button will actuate the camera, but only image is of a black box.using the display button to turn off the lcd does not...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 18, 2009 | Canon PowerShot S3 IS Digital Camera
Can't see anything on screen or thru viewfinder
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jul 08, 2009 | Canon PowerShot S2 IS Digital Camera
Screen and viewfinder only shows black....no picture
Are the pictures also coming out black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 02, 2009 | Canon PowerShot S5 IS Digital Camera
Canon T70 35mm SLR Camera Logo
179 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
