Question about Panasonic KX TG2570 Cordless Phone
I can find the owner's manual for Panasonic cordless telephone Model KX-TG 2750. How do set a new answering machine recorded greeting.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
You can download the manual from the manufacturer's web site at
http://service.us.panasonic.com/OPERMANPDF/KXTG2570B.PDF
Posted on May 12, 2011
WANT TO CHANGE OUTGOING MESSAGE ON PANASONIC KX TG 4131.
The base of your phone system is the KX-TG4131. The handset/base combination packs have a slightly different model number (KX-TG4132 for example). Assuming that you want to change the greeting of the answering system, you need to press Menu # 3 0 2 (when the phone system is in standby mode) from a handset. (Alternatively, press Menu and use the arrow keys to navigate to Answering Device. Press Select and navigate to Greeting. Press Select again and navigate to Record Greeting. Press Select and navigate to Yes. Press Select one more time. When you hear the beep, hold the handset about 8" (20 cm) away from you and speak your new message clearly. Press Stop when finished. The recording will cut off if your greeting is longer than 2 minutes. To exit the menu system, press Off. Make sure that the Answering system is on and your recorded greeting should play when you can't pick up the phone within the set number of rings.
See page 21 or page 33 of the manual. Panasonic has the manual here: ftp://ftp.panasonic.com/telephone/om/kx-tg4132_mul_om.pdf .
I hope this helps.
Mar 23, 2018 | Panasonic Lands Phones
Just purchased Panasonic model #KX-TGF380 phone system. How do I turn off built in answering message and record my own message
Make sure that none of the handsets are in use. First, record your own message. Press Menu then # 3 0 2 from the base unit or any handset. Menu is the middle soft key below the LCD screen on the base unit. It's the right soft key below the LCD screen on the handsets. The # key is below the 9. Use the Up/Down arrows to highlight Yes and then press Select. See the screen for the appropriate soft key. After the beep, speak your message while you are 20 cm (8 inches) from the microphone on the handset or base unit. Press Stop when finished. (The phone will stop recording if your message is 2 minutes long.) Press Exit on the base or Off on the handset to leave the menu system.
Turn on the answering machine. Press the button with cassette tape symbol on the base. Press Menu # 3 2 7 on the handset. Your greeting should be heard by incoming callers unless the unit is set to Greeting Only or the memory is full. To check this, press Menu # 3 0 5 . Again, use the up/down arrows to highlight your choice. Press the appropriate soft key to Save the setting.
If you do not want to use the numbers, you can use the Up/Down arrows and Select. Press Menu, highlight Answering Device. Then highlight Greeting. Then select Record Greeting for the first step.
These steps are available in the manual. All except for the greeting length are on page 57. The last section is on page 63. This is available from the product site: http://shop.panasonic.com/cordless-corded-telephones/corded-telephones/KX-TGF38.html#q=KX-TGF380&start=1 . Click on the Support tab. The direct link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tgf380_en_om.pdf .
I hope this helps.
Jan 13, 2017 | Panasonic Lands Phones
Record message on Pansonic kxtg4021 cordless phone answer machine
With the phone in standby, press Menu on one handset. Use the Up/Down arrows to navigate to Answering Device. Press OK. Navigate to Greeting and press OK. Select Record Greeting and press OK. Highlight Yes using the Up/Down arrows and press OK. After you hear the beep, hold the handset about 8" (20 cm) away and speak your message. Press OK when you have finished the message. (The recording will end after 2 minutes.) Press Off to exit the menu system.
The answering system may need to be on for this option to be available. You can turn it on by pressing the Answer On button on the base. Alternatively, press Menu and navigate to Answering Device. Press OK and select Answer On. Press OK. Press Off to exit the menu.
The manual for the KX-TG4021 is available from Panasonic on the product site: http://shop.panasonic.com/support-only/KX-TG4021N.html . The direct link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg4011_mul_om.pdf . See page 28.
I hope this helps.
Jul 09, 2016 | Lands Phones
Record personal greeting
Follow the instructions on page 28 of the manual available at ftp://ftp.panasonic.com/telephone/om/kx-tg4011_mul_om.pdf
Jul 09, 2016 | Panasonic Kx-Tg4021n Cordless Phone With...
How do I change message on panasonic KX-TGA652 cordless phone
To change the answering machine greeting message, make sure that the phone is in standby mode. Press Menu on the handset, then navigate to Answering Device with the Up/Down arrows. Press Select and then navigate to Greeting. Press Select again and highlight Record Message. Press Select and then confirm this by selecting Yes and pressing Select once more. Hold the handset about 20 cm (7.5") away from your mouth and speak the new greeting clearly. Press Stop when done and then press Off.
Alternatively, you can press # 3 0 2 after pressing Menu. Then highlight Yes and press Select. This is given in the manual for the phone. Panasonic has the manual here: http://panasonic.ae/en/manuals/KX-TG6541.pdf . See page 32.
Note: this greeting will only play if the answering system is on and you have the system respond before any telephone provider Voicemail system answers the call.
I hope this helps.
Apr 14, 2016 | Panasonic KX-TGA652B Cordless Phone 3 Pack
Model KX-TG4021 - How do I put in a new answering message?
To record a new greeting, you must use the handset. Press Menu and use the Up/Down arrows to reach the "Answering System" line. Press OK and then navigate to the Greeting. Press OK again. Select the line "Record Greeting" and press OK. Select Yes to confirm recording a new greeting and press OK. After the beep, hold the handset about 8" away and speak clearly. Recite the entire message that you wish to record; the message must be under 2 minutes long. Press OK to save the greeting and press End to exit the sub-menu. Make sure that the answering system is on (and set to pick up on fewer rings than any other voice mail system, if your telephone provider offers one, for example). Make sure that the memory is not full. The system can only accept 18 minutes of recordings, including the greetings.
The manual for the KX-TG4021 is available from the product page: http://shop.panasonic.com/support-only/KX-TG4021N.html . The direct link to the manual is http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF . (Note: there are several models that use the same manual.) See page 27 and the subsequent pages. The N indicates the region in which Panasonic sold the model.
I hope this helps
Oct 23, 2015 | Panasonic Lands Phones
I would like to change the answering machine message
Record a Personal Greeting
Access the answering system from any handset. Wait until the system finishes its announcements, or press 5 (Stop) to skip them.
Press 8 (RecNewGreeting).
Wait for the system to say "Record greeting," then begin speaking.
When you're finished, press 8 to stop recording. The system plays back your new greeting.
To keep this greeting, press End. To re-record it, go back to step 2.
Aug 21, 2013 | Panasonic KX-TGA101S Cordless Handset
My panasonic KX-TG5663B's screen says 9 and a little circle. The answering machine is not working. It just tells callers we are not available and hangs up. Can you assist us with this issue?
The answering system is set for the greeting mode. It will enter this state if the message memory is full or when the caller recording time is set to Greeting only.
To change the caller recording time from the handset, press Menu 0 6 2 then select the desired length of the recording. Then Save the setting and press Off.
If the phone is in this state, then delete messages from the unit. Then reset the caller recording time.
The manual for the phone is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/5-8-GHz-Phones/Operating-Instructions/model.KX-TG5653B.O#ts .
I hope this helps.
Mar 30, 2011 | Panasonic KX-TG5653B Trio Cordless Phone
Caller ID not functional in Model KX-TG-9331T and 9332T
Do you have the converter that converts your caller id to U.S. caller id?
Mar 15, 2010 | Panasonic KX-T7633 Corded Phone
How do i record a answering message on my panasonic answering m/c
Hello jmkraus,
To record a greeting message on the Panasonic Panasonic KXTG1855.
(2 minutes and 30 seconds max.):
1 Press [OK]
2 Press up/down [^]/[V]: 'Answer System' : [>]
3 Press up/down [^]/[V]: 'Record Greeting' : [>]
Hold the handset about 8 inches away and speak clearly into the microphone.
4 Press [OK] to stop recording.
5 Press [OFF]
Here's the Panasonic KXTG1855 manual download link:
http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg1855.html
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | Panasonic DECT 6.0 Expandable Cordless...
Panasonic KX TG2570 Cordless Phone Logo
282 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
