Question about Whirlpool Duet GHW9150P Front Load Washer
Thanks for posting fix for Whirlpool Duet GHW9150P
Catriver - I applied the fix you posted (change water inlet valve).. so far, so good. I wanted to drop a quick Thank You for taking the time to post the solution. Though we just finished replacing part of the hardwood kitchen floor due to a washer leak.... we hope this fix will prevent repeat problems in the future....Thanks again
    President:
  • 878 Answers
You are welcome partner...good going!
Posted on May 28, 2008
Code is F20, what does this mean?
Hi
Error F20 means Water Inlet Problem-no water or insufficient water supply. This issue can appear due to faulty inlet valves or due to blocked inlet hoses. Also check the filter screen at inlet valve, clean them if they are dirty. Select PAUSE/CANCEL twice to cancel the cycle. Unplug the washer or disconnect the power. Now check whether water faucets completely turned on? Make sure that the water inlet hoses are not frozen. If above things seems to be fine then you would need to replace the water inlet/fill valve.
Hope this helps... Please post back if you need more information. Daniel
Mar 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Possible causes for HF error. It is in the cold
Hi
Thanks for using FixYa. You are right, FH error indicates an issue with the water supply; this error occurs when after 30 seconds the control does not detect the water entering the machine and the valves turn off & error code is displayed. Check the cold water inlet valve for any clogs and try to clean it, also clean the screens in the inlet valve. If still it’s not resolved then the only option is to replace the valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer flashed FH. I hit cancel load after i turned water back on now it won't do anything but sit there and buzz. What do I do?
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display and then check:
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Thanks
Rylee
May 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet fills when off
It's Quite easy.
To test Inlet valve, follow the below guide :-
http://www.acmehowto.com/howto/appliance/washer/check/inletvalve.php
To test the Water level switch/Pressure switch, follow the below guide :-
http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is filling with water when it is off. it only drips, but two days in a row it was filled up above the bottom of the door openeing and spilled on the floor,
This problem is either attributed to a defective water inlet valve, or defective pressure switch. An easy way to determine which one may be causing the problem is to unplug the washer, but leave the water taps on. If the washer continues to fill, you have a defective water inlet valve. If the water stops, I would recommend changing your pressure switch.
Post back and let me know if you require further assistance. I hope this helps you.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer Leaking Water Into The Tub When Not In Use
Replace the water inlet valve, it not closing all the way.
Aug 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9100 LW1 Front Loading
Probably a good assessment. I wasn't trying to second guess your repairman. I just wanted to make sure you were able to have the knowledge to eliminate some of the possibilities yourself. That way, you feel a little more confident that you're getting the correct repair. It sounds like the solenoid is probably clogged or scaled up from sediment. Let me know how things turn out for you.
May 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water in leaking into tub overnight
One of the solenoids in part #8181694 is not closing completely. This part is easy to replace.
1. Turn off the water from both inlets and unplug the machine.
2. Unscrew the hot/cold from the machine. You may want to use a bucket to collect the 2 cups of water that will pour out of the hoses.
3. From the rear of the machine, use a #20 torx head to remove the 5 bolts holding the top cover.
4. Slide the cover back and lift to remove.
5. See the attached picture. The red arrow in the upper left corner points to the inlet valve.
6. Note the color of the electric connections. The white plugs are on the right. The black on the left. Unplug these.
7. From the rear of the machine, remove the #20 torx bolt which holds the valve in place.
8. Using pliers, pinch the hose clamp and pull the rubber hose from the inlet valve.
9. Lift out the inlet valve.
10. OPTIONAL : Connect the valve to a garden hose using a female/female hose bib. See the attached picture. Turn the part upsidedown and shake it. This will loosen the solenoid and some water will squirt out. Turn it rightside up and see if the valve seals itself. Repeat if necessary. Repeat on the other inlet. In the picture you can see the leak coming from the valve.
Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
WHirlpool Duet Washer
Swede, you need to replace the water inlet valve. Part number 8181694. This is an easy fix. Just remove the 3 screws that are in back holding the top on. Slide the top back and you will see the valve. Couple of screws and a clamp and it will come right off. Catriver..post back.
Jan 19, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
235 people viewed this question
Dan Webster
Dan Webster
Sal De
