Question about Canon EOS Rebel XS 35mm SLR Camera
My canon xr rebel switches on, focuses but will not fire or display!
  • 231 Answers
Dear sir,
the first suspect is your battery,ahich is running in low battery....kindly recharge the battery for few hours and then put your camera on........ also the problem can be because of the rough moving of lens in and out because of accumulation of dust and lint inside,which cause this problem.
next,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest canon service centre
thank you.....take care................
Posted on Oct 06, 2010
  • gymboreedrea Nov 09, 2010
    Wow, mine just started doing the same exact thing....... what did you end up finding to be the problem if you don't mind me asking? Thanks Gymboreedreams@me.com
Canon Rebel EOS Rebel Ti1 will not auto focus
The lens needs servicing, because the lens is stiff the auto focus motor cannot turn the lens to focus.
Mar 24, 2012 | Canon Digital Rebel EOS 450D EOS Rebel XSi...
Canon EOS 400D Flash Problem
yes..that's a twitchy button all right..can you inspect it to see if there's any accumulated dirt/grease can cause it to actually 'stick'
Mar 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel T3 focus problems
in manual mode, will not try to focus itself, my be the manual auto switch is faulty, or the focus related mechanism not rotating the lens, open the lens carefully check the focus motor and gear set (engine is the technical term)
Sep 01, 2017 | Canon Rebel XT / EOS 350D Digital Camera
When I press the shutter half-way, it is my understanding I should see a red light in the window telling me it is focused....there's no light. Also, my BEEP is turned ON, but it never beeps??? Canon...
The Canon Rebel XS is a digital camera not film. Most of your problems may stem back to not having a media card installed. Here is a great link for the Canon EOS Rebel XS showing important functions http://www.dcresource.com/reviews/canon/eos_rebel_xs-review/ If you have a media card installed and it has been formatted to the camera then the red light you mention will only flicker for an instant on your focus point, you got to be pretty quick to see it. The in focus light you want to see is a small green dot in the lower right corner of the viewfinder. This "green dot" needs to be solidly lit not flickering. When the camera has achieved focus the "beep" should sound, I suspect you haven't reached focus yet. Not focusing could be as simple as having the lens switch set to manual focus or the camera set to manual focus.
Nov 17, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Camera has no display, appears to be locked up, shows busy through veiw finder, otherwise focus ok but no picture taken. Battery and SD card ok.
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Nov 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
"BUSY" Problem
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
Apr 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Flash pre-firing like mad?
It is your camera using the flash to assist in focusing, if it bothers you you can change it in your menus, I have a XTi so yours will differ slightly.
Switch your camera to "P" mode.
Press "Menu" button.
Go to setup menu 3
scroll down to "Custom Functions (C Fn.)"
Press "set".
press to the right until you find "AF - assist beam"
Press "set".
And press up or down.
Set to "Does not emit"
press "set"
Press "menu" button twice.
Mar 08, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Camera won't shoot with lens on Auto Focus
Talked to canon support, they suggested to send lense in for review/repair. They said it could be the motor, I think it was a gear problem based on the noises and jerkiness of the focusing action while in manual focus (manual focus gave out as well). Cost TBD - "would definately be more than $50. I shopped around and elected to buy a new lense rather than try to hassle with the repair, shipping, insurance, and the wait, etc. Besides, I have a deadline that I need the lense for, so repair at Canon really became a non-option. I think the cost would've been pretty much the same in the end as the new lense, since this wasn't one of the costlier of lenses to begin with.
Mar 10, 2008 | Canon Rebel XT / EOS 350D Digital Camera
The flash keeps flashing
hi sneakers
the camera is firing the flash to help it auto focus,the only way to stop it find an area of the picture that has more light/contrast or switch to manual focusing.
regards
ian
Dec 27, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS Rebel XS 35mm SLR Camera Logo
189 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
