Question about Sony VAIO PCG-FRV27 Notebook
SONY VAIO PCG FRV27 I power on the laptop and the screen shows up but its very dark i adjusted contrast but it is not very visible
  • 2,567 Answers
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen
Posted on Oct 06, 2010
How do i adjust the contrast
Right click on the desktop and go into display properties. You can adjust the contrast there.
Hope this helps.
Jun 29, 2012 | Sony Vaio PCG 7154M Laptop Universal AC...
Sony vaio pcg-frv27 turns off after a while, I'm using ac power with batteries not in it.
Most likely overheating, check if it is getting hot as it shuts off, by hot I mean hard to touch the base.
If it is, you will need to remove the bottom cover and clean out the accumulation of any dust by the heatsink
Mar 26, 2011 | Sony VAIO FRV27 Notebook
Screen goes dark
It could be the display power inverter or the illuminator is going out. generally the inverter goes first.
Apr 29, 2010 | Sony VAIO PCG-K33P Notebook
Vaio PCG-9S1L Screen is very dark, extremely hard , LAPTOP SONY
As stated in your post "two year old may have dropped it"
If this is true than the backlight has probably been damaged. The small flourescent tubes that generate light through the LCD display.
Email service@lanprotec.com for service options
Mar 01, 2010 | Sony Computers & Internet
Hi guys, I keep getting an error message that says: Stream reading error when I try to use the sony vaio recovery wizard. My computer is the sony vaio pcg-frv27 notebook. The first problem was that...
Try rebooting and hitting the F8 repeatedly as soon as the boot sequence starts. When it comes up to an options screen select repair. From there you can let windows try to repair or select to install to the factory settings.
Mar 14, 2009 | Sony VAIO FRV27 Notebook
I have a sony viao pcv-frv27
are you on your battery or plugged in? It's not likely to make it as dark as you described but if you press the function key 'fn' key and usually the up arrow key (which has a sun symbol) it should brighten. From there if this dioesn't work you can try downloading new graphics drivers as last ditch effort but after that will require opening and checking connection to make sure screen hasn't died.
Jan 02, 2009 | Sony VAIO PCG-FRV27 Notebook
Broken key board
well i really dont think so you can always order online i know you cant
Dec 10, 2008 | Toshiba Satellite 2775XDVD Notebook
Sony VAIO PCG-K25 PC Notebook
have you tried your power management settings?
Dec 07, 2007 | Sony VAIO PCG-K25 Notebook
Sony VAIO PCG-FRV27 Notebook Logo
235 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
