Dell has informed me that the mother board and memory is shot and the power cable. i can not get power to lap top any thing i can do to fix problem
    President:
  • 2,992 Answers
If the motherboard is truly defective, you may be able to locate a replacement online. There are many boards available from a number of vendors. A good starting point is always eBay. The same is true if you need a power adapter. Lots of replacements are available.
If the trouble is that the power jack has broken loose from the motherboard, it might be possible to repair the one you have. It's a common problem in laptops for the solder connections holding the jack onto the board to break because of flexing the power plug. Sometimes it's only necessary to resolder those connections. Most service places (especially the manufacturer's authorized servicers) would rather replace the board than try to repair it. You might want to try another shop and get a second opinion.
If you do need a motherboard, it may not be worth the repair, though. With laptop prices pretty low, you might find between the part price and labor, it may not cost much more to replace the computer. You can always remove the hard drive and transfer your personal files to a new machine.
Hope this has given you some help in making your decision. Good luck and thanks for using Fixya!
Posted on Oct 06, 2010
    Master:
  • 388 Answers
I have never found dell support any help how did they come to that dissision tell me the the make and model no.
Its a dell model pp37l power on has black screen tried reseating memory even got new memory still has black screen when powers on
usually when you get a black screen on a laptop it has something to do with the graphics processor or the cable connection to the screen or worse its been dropped or overheated the mother board. hope that points you in the right direction
Mar 04, 2015 | Dell Computers & Internet
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Why is my lap top just intermittently beeping with a black screen
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 07, 2012 | Dell Inspiron M5030 Laptop
I am trying to replace memory.I get referred to the product information guide ,which I cannot locate.Assisstance please.
Need more information.
Are you trying to find out the specifications of supported memory for upgrade or are you physically just trying to replace memory?
What is referring you to the information guide?
Jun 10, 2011 | Dell Inspiron 6000 Notebook
I HAVE A DELL INSPIRON 6000 SERVICE TAG HN98T61. THE AC POWER SUPPLY WELL NOT CHARGE THE BATTERY NOR WILL IT POWER THE LAP TOP. THE CHARGE LITE DOES NOT COME ON. I AM SURE OF THE AC POWER SUPPLY IS OK. IF...
Take a multimeter, and measure the VOLTAGE and AMPERAGE being emitted by the AC power-supply. If "none", or much less than the ratings printed on the label, then it's time to replace the power-supply.
Otherwise, it most-likely is the connector where the AC adapter is plugged-in to the motherboard that is not transmitting, i.e., electrically-disconnected from the motherboard.
Maybe, resoldering the leads from the socket to the motherboard will fix the problem. Or, take the laptop to a qualified technician, for proper repair.
Oct 17, 2010 | Dell Inspiron 6000 Notebook
My lap top computer (Dell) . The hookup to the electricity is broken off . The little prong that sticks out for you to hook up to is broken off inside the computer on the mother board
This will require attention from a technician that can disassemble your notebook and replace the power connector. Contact Dell or a reputable local computer repair shop. Most likely, you will receive faster and more affordable service from the local shop.
Hope this helps.
Mar 11, 2009 | Dell Inspiron 1000 Notebook
Ihave a emachines modelT2792 and have een told the mother board is no good as well as the power supplycan i get another mother board for this computer or is it too old to fix it is about 2 years old
when all some other parts are good maybe you can replace the the mother board and the power supply.
you should find motherboard replacement that will fit to your processor and Memory.
if the memory , processor, hard drive are good, then you can contact your vendor if the have replacement(mother board) and power supply.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 15, 2008 | Computers & Internet
Hard drive installation
You should be able to install that drive. The biggest variable is if it is a SATA or PATA drive. This model was built for SATA drives, but I think you may be able to get a PATA drive to work with the right adapters.
For the step by stem directions see the link below. It will take you right to the Dell support page. Refer to the "Adding a Second Hard Drive" section.
https://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Feb 21, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
