Question about Nikon COOLPIX S10 Digital Camera
Lens error i have a problem with my camera,its as following: just when i turn on the camera ,it gives me an error message "lens error",and the ony way to switch it off is removing the battery...
  • Anonymous Jun 13, 2008
    I have a CoolpizS10 and have had *LensError* problems twice and on thinking back I have turn off camera when I have taken a wide angle photo and not closed the lens. I have stupidly done it again and this time no banging or shaking will move it.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • Nikon Expert
  • 122 Answers
This can work with CoolPix S10
1) Remove battery.
2) Replace Battery (Insure it is fully charged)
3) Press the Shooting/Preview button and keep pressing it while you press the power on button. This tells the camera to go into PREVIEW MODE without checking the lens. See if you can preview a few photos and that it works in preview - If it does NOT I cannot help you here.
4) If the Camera Works in Preview mode then press the Shooting/Preview button to put it back into "Take Photo Mode".
5) There can be a delay but it starts up without the lens error.
6) Make sure the ZOOM IN and OUT works and in most cases if the lens operates then you can take a photo. If the Zoom in and Out does not work you have a jammed lens.
7) If the LENS is Jammed AND it is OUT of warranty you 'might' want to tap the lens barrel against your palm. I have found when you remove the battery you can gently tap the lens into telephoto mode by tapping the back of lens assembly into your palm.
Posted on Jul 08, 2008
    Scholar:
  • 70 Answers
Some problem can be fixed easily, but some need more.
Read and follow in this page:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 28, 2008
Shooting is not possible, turn the power switch to off and on or reinstall the battery
Hi there :the Error 99 is a comunication error between camera body and lens .are you using Canon lens?Try the camera body with a/another Canon lens in Camera body and try the lens on another Canon camera.With this troubleshoting you can know if the camera body is failing or lens is failing.I hope this information will help you.
Nov 29, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
When I turn the camera on, the following message is displayed: " Lens Error, Restart Camera" How can I fix this problem?
you will have to take the camera to a service station to get the lens repaired. the motor that drivers the lens is damaged giving the above error. thanks
Apr 20, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 300d gives error 99 and does not work
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Nov 28, 2008 | Canon Digital Rebel / EOS-300D Digital...
Lumix TZ3 keeps giving the same error message: "Please turn camera off and then on again"
sorry to tell you guys this but you definetly have lens faults, for you firwol i can say that you have a focus lens or image stabilizer fault, bob80 sand can definetly mess your lens around and is going to need a service. you can check the error codes. you need to do exactly what i say. turn camera off, mode switch to red camera selection, this has to be done quick, turn camera on holding the ois+ arrow up button, then quickly hold ois+menu+arrow left. post the error then i will tell you what is wrong.
Jun 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Nikon COOLPIX S10 Digital Camera Logo
597 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
