Question about Panasonic PT-LB10VU Multimedia Projector
Pt-lb10vu has extra colors
There are extra splotches of blue on the screen.
  • Panasonic Master
  • 1,779 Answers
Chances are your Blue and Green Lens' need replaced. Common problem with projectors that are used more than what they were designed for.
Posted on May 28, 2008
Green haze on panasonic pt-52lcx15
Your EEPROM is corrupted and needs to be reprogrammed. You need a EEPROM data corection tool. Part# LSUQ0100. It will come with instructions on how to restore your EEPROM data. Good luck.
Apr 19, 2012 | Panasonic PT-52LCX15
Small red splotch in middle of the screen
sorry to tell you but you have a bad red lcd in the light engine you have to replace light engine
Feb 04, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic projector TV PT-43LC14 has a light yellow splotch on the left hand of the screen. Can this be fixed?
yes and no. it is a burn spot on the light filter on the blue lcd panel due to excessive dust and heat. panasonic does not sell individual parts of the optical engine, so you'll have to replace the entire engine. to avoid it happening again or getting worse, keep the projector cool and dust free. use canned air to blow it out.
Nov 30, 2009 | Panasonic PT-AX200 LCD Projector
Blue splotches on the screen what is it?
hi friend,
Computer monitors work the same way. Here's a few web sites that list proportional colors:…
or just plug "rgb colors" into Goggle.
There's more than you may want to know about it here: thank u for using fixya regards, sivaranjini
Aug 15, 2009 | Mitsubishi WD-62526 Projection TV
Blue/Yellow Splotches on screen
It will be 12 appliance years old in October. Not much justification for trying to repair it.
Mar 23, 2017 | Sony KDF-E50A10 50 in. LCD HDTV
PT L711U + all my black colors are blue
Your projector needs to be aligned and serviced, normal occurrence
after 6 years since service.
Apr 18, 2009 | Panasonic PT L711U Multimedia Projector
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
No blue colors projected on screen
Only a few causes for this problem. "Splotches" are usually caused by dust in the light engine which can sometimes be blown out using compressed air. Pink picture is caused by either data or burnt lcd card. Procedure for data is: put tv to ch. 3 and turn power off. simultaneously press input and power on set for three seconds to access service menu. Be very careful not to change settings other than what needs changed. These adjustments are changed using directional arrows. Navigate to "memory init" then hold (r) arrow button for 5 seconds. You will know if it worked. Then exit and/or turn set off. Please let me know if this is successful as I have additional info you may need. Good luck, Russmann.
Jun 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Different colors on the scanner screen
I didn't find a fix. I went to Best Buy and they said it would cost more than it was worth to fix. So I bought a new one. Thanks, mittenshadow
May 29, 2008 | HP ScanJet 5300C Flatbed Scanner
Optoma h27 colour issues
Check to be sure that the projector is in the correct mode. If it is expecting an RGB signal and you send it (Y,Pr,Pb), you will see the picture as you describe. The same works for the above reversed. In all likelyhood, you are sending RGB and the projector is expecting the other.
May 07, 2008 | Panasonic PT-LB10VU Multimedia Projector
Open Questions:
Panasonic PT-LB10VU Multimedia Projector Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
