Question about Kenmore Dishwashers
Kenmore dishwasher #665 only sprays water for a sevcond. will run cycles just won't spray more than a second
  • Kenmore Master
  • 3,740 Answers
This is a sign of food particulate that is blocking the impeller inlet under the lower wash arm. Remove the lower wash arm noting EXACTLY how it comes off as you remove it. Then clean out the particulate. You may have to unscrew the lower wash arm tower also to get to the particulate.
Once yopu get it cleaned out it should work just fine. This does not happen often but..it does happen. It should not repeat anytime soon.
If you need exact instructions with part details I will need your full model number.
I think this is your dishwasher:
http://c.searspartsdirect.com/lis_png/PLDM/10054505-00004.png (Enlarge)
You may have to remove Item 14 (ONLY) to clean off the screen Item 1
Thanks for choosing FixYa.
Kelly
Posted on Oct 06, 2010
Dishwasher won't run. Worked yesterday, checked curcuit breaker, ok. water is in the bottem of washer but below the float level.
First, check the dishwasher filter and make sure it isn't clogged. Your owner's manual will have simple instructions on how to access and clean your dishwasher's filter.
Next, check the drain hose. Does it look flattened or kinked? Do you see any sharp bends? If so, straighten out the hose with your hands and manipulate it so that it regains its rounded shape.
If your dishwasher drains through the garbage disposal, try running the garbage disposal for a bit to process and clear any food. If that does not get the machine draining, you may have a deeper clog. However, most drain hoses clog either at the main household sink drain line connection or the garbage disposal connection.
Does your dishwasher spray your dishes, but it does not advance to the next stage and drain the dirty water? The timer controls the start of the draining process, so you may need an entirely new timer or a new motor for the timer. Repair service is recommended.
In some dishwashers, standing water is caused by a valve that fails to open and allow the water to drain out. This valve is controlled a solenoid that the timer controls. A malfunctioning solenoid could be the problem.
For more troubleshooting tips and solutions, see Dishwasher not draining. I hope this helps!
Sep 27, 2012 | Kenmore 665
Breaker at dishwasher trips right after water has filled.Spray arm has not turned.
There is an electrical short circuit, check/reverse the leads going to the pump or heater.. Sounds like controls and water valve are fine. If wires are not connected to the correct locations you need a new motor because it is internal.
Aug 26, 2012 | Kenmore 665
Hello, I have a Kenmore Ultra Dishwasher, model # 665.16533200. Lately the top rack dishes have not been getting clean. Also the glasses with indented bottoms, that are normally full of water at the end of...
might wanna check the connections on the back of it and make sure nothing has broken behind it....also may wanna get a mop and some towels something tells me its throwing water out the back side of itself while its running
Apr 16, 2017 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore model 665 17539201 Does a very poor job of cleaning, runs through all cycles
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 01, 2011 | Kenmore Dishwashers
Why kenmore 665 leaks under door
This is common if the wrong detergent was used or some regular sudsing soap like hand dish washing soap was accidentally used. Clear the suds if there by adding a small amount of cooking oil to the soapy water then wash for a bit and cancel drain. Repeat if needed.
If this is not the problem look for something blocking the spray arms from turning, if they spray in one spot only they can splash water out the front.
Check the unit for level, if it is tilted forward it could be spilling while washing.
Look for cracks in the spray arms where too much water sprays from one place.
Make sure the middle spray arm has not fallen off. If it continues try moving the rack to the higher or lower position and see if this helps
Apr 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher doesnt wash top rack ....model 665 1352k700...ser fu4706403
HI,
YOU WILL PROBABLY FIND THE TOP SPRAY ARM IS BLOCKED WITH FOOD. UNSCREW THE SPRAY ARM AND MAKE SURE ALL THE SMALL HOLES ARE CLEAR OF ANY BLOCKAGES AS THIS IS WHERE THE WATER COMES OUT OF TO WASH THE PLATES.IF THESES ARE BLOCKED THEN YOU GET POOR WASH RESULTS
Jan 22, 2010 | Kenmore Dishwashers
My Kenmore stand alone dishwasher leaks. the water seems to come out the front at the bottom of the door. i have cleaned the seal, but it doesn't seem to help. Any ideas?
the spray arm is clug in the hools or your spray arm stuck, put the spray arm in a position you remember run the machine for few second and open the door to see if the arm move.
Jul 13, 2009 | Kenmore 17822 Free-standing Dishwasher
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    I have a kenmore 665 dishwasher where the spary arms do not spin.
    • First, check water level. Start machine, wait until the machine begins main wash. Open the door, the water level should be just below the heater element. If too low replace inlet valve.
    • If you can't hear the wash motor running or is just humming, the motor may be bad.
    • To check if the food chopper is blocked or broken;
    1. Remove lower spray arm by holding the arm and rotating the spray arm retainer.
    2. In the back of the tub, unclip or remove the screw from the upper spray arm supply tube.
    3. Rotate the lower spray arm support to the right while disconnecting the supply tube from it.
    4. Remove the four torx screws from the sump cover, remove assembly.
    5. There may be a primary filter in the left side of the sump, if so, remove the torx screw and the filter.
    6. On the right side there is the chopper assembly cover. Remove the torx screw and cover to expose the chopper.
    Hope everything goes well for you,
    Regards
    Richard
    Feb 02, 2009 | Dishwashers
    Kenmore Ultra Wash 3 Leaking
    Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
    "Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
    I checked mine and got a nasty surprise. Who knew it could get so dirty.
    Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
    Dishwashers Logo
    136 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
