Question about Whirlpool Refrigerators
Refrigerator giving problem like the items in the refrigerator are not cooling
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101.
Posted on Oct 08, 2010
Samsung srs580dw fridge freezer after being
Most refrigerators get their cooling from the freezer. I suggest that you give it some time, and make sure the small door or damper leading from the freezer to the fridge is open and not obstructed by any food items
Aug 25, 2013 | Samsung RS2556 Side by Side Refrigerator
I have a GE profile that is 3 years old ,side by side model # is PSC25MSWASS ,the problem about this frig is that frost build up in the refrigerator side the freezer is good,so the refrigerator is not...
If frost is building up on the REFRIGERATOR side and NOT the freezer side, then the cooling tubes could become blocked. I would first check if the cooling fan http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PSC25MSWASS/0432/0165000/G0902008/00010?blt=06&prst=&shdMod= Item 922 is operating, if it is then I would check to make sure the the damper is opening or not it is Item 923 on the diagram. If both of them are function properly, then I would check the sensor http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PSC25MSWASS/0432/0165000/G0902008/00008 Item 236.
Jun 14, 2011 | Refrigerators
Ge profile side by side refrigerator is not cooling to the recommended temperature
The GE profile has a smaller condensor grill, so keeping the area free of debri and dirt is very important. Check the grill and vacuum it off, also make sure that the back is kept clear of items since it needs front to back air flow. If that doesn't help the cooling then I would check for ice build up in the freezer (behind rear inner panel) that could be giving the thermostat the wrong readings.
Jun 07, 2011 | Refrigerators
The freezer items are frozen,the refrig items are getting warm.i set it to the highest no.7 in the frig and its not getting colder
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
I have a montegormery wart side by side regrig and freezer. The freezer working wonderful, however refrig barely keeping items cool
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Jan 29, 2011 | Refrigerators
Need info for a kenmore side by side refrigerator model#59652673202 it it not cooling nor freeszing ; the light works and the fan works but not cooling any side please help me
Good day,
With that amount of info it would be hard to try to pinpoint it. Here's a list of items that can cause a refrigerator to not cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see it could be one of many,many items. If your handy with a meter you might want to start at the bottom back of the machine where the compressor is located.
Sounds as if it is not running, or running without refrigerant in the system.
Also, if it has a cooling fan motor in that area, make sure it runs, since all fan motors are wired to run at the same time.
Oct 15, 2010 | Kenmore 44103 Side by Side Refrigerator
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Oct 11, 2010 | Whirlpool Refrigerators
Our Refrigerator is not keeping items cool
take all shelfs out of freezer section and take light cover off just bellow the icemaker . then take out two screws behind light cover pull panel off and see if its packed with ice . If it is i bet the defroster light towards the bottem is out
May 23, 2010 | GE GSS20IEP Side by Side Refrigerator
Layed refrigerator on its side to move waited 3 days plugged it in worked fine for 3 days then electrical smell and it doesn'tget cold. can i fix it
Fan motors are great item to give off a burning smell when failing.
You have one in the freezer compartment behind the back panel.
You should be able to hear it when you open the door to the freezer.
A second motor is behind the cover panel at the bottom rear of the machine near the compressor. Failure of either motor can cause no cooling, and a burning odor.
There is a calrod heater located in the freezer compartment behind the real panel that can short and burn, but it would not immediately cause rapid cooling failure unless it burned a hole in the evaporator causing a total loss of refrigerant. ( I've seen it happen, but it's rare). Beyond those items wiring runs throughout the machine and can be suspect especially if the machine was transported on it's side. Refrigerators should always be moved in an upright position.
Nov 02, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
75 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
