Question about HP 378248-001 keyboard for Compaq nc6110, nc6120, NX6120
Respected Sir/Madam I am facing a problem with my hp nx6120 laptop. hdd not detecting. In BIOS show hard disk but not boot from hard disk. I changed this hard disk but problem is same. system not boot. please give me the right solution.
    Master:
  • 388 Answers
You wil need to install a operating system lik vista, windows 7 ,xp.
Posted on Oct 06, 2010
Just replaced my hdd on Compac Presario 2100 but the system is not detecting it.
This model laptop came with a 60Gb hard disk and if you installed a much larger capacity hard disk then the BIOS cannot detect this hard disk.
For the BIOS to detect a large hard disk a BIOS upgrade is required (if there is one available) Check the HP/Compaq WEB site to see if there is a BIOS upgrade.
If not the try a 120Gb or smaller capacity hard drive.
As an alternative -
You can keep the existing hard drive in your laptop and use an external USB hard drive to store your data.
Nov 10, 2012 | HP Compaq Presario 2100 Laptop
On the BIOS set up, it will show HDD (none) but if i return the old one the system will detect it.
This model laptop was installed with a 60Gb hard disk. When you installed a much larger hard disk the BIOS could not detect this hard drive.
Check the HP/Compac WEB site foe a possible BIOS upgrade that can support a large hard drive. Otherwise try a hard drive 120Gb or smaller.
Nov 10, 2012 | Compaq Presario 2190US Notebook
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Jun 07, 2011 | Computers & Internet
I have laptop hp compaq 6710b, it cannot boot & hard disk not detecting.
Step1: Go to the BIOS and select first boot devise as hard disk. If you get same problem or hard disk not detecting. Replace the hard disk. Step2:If BIOS is not showing replace the RAM and check it..
Thanks..
Feb 10, 2011 | HP Compaq 6710b Notebook
Turn on notebook compaq nx6120, always 3 beeps and message "Fixed Disk Parameter Table or BIOS Error" and the low line is "System Halted", And another, i remove the HDD from my notebook in order to...
You should have gone into your Bios pages first.Press F2 whilst booting,learn how to to configure these pages,use the "tab" button to navigate and arrow keys ,Save and exit or restore to factory defaults,learn how to use these pages to enable correct boot sequence--good luck!
Davey Snake!
Oct 23, 2010 | HP Compaq nx6110 PC Laptop
PXE-E61: media test failure check cable
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 18, 2009 | HP Pavilion dv1000 Notebook
PXE-E61: MEDIA TEST FAILURE, CHECK CABLE PXE-M0F: exiting Broadcom PXE ROM. Operating system not found. how 2 solve or repair? help me...
May 14, 2009 | E-Machines eMachines Desktop PC
Problem in installing windows XP
Maybe a bios update is needed.
Mar 27, 2008 | MSI 945GCM5 Motherboard
Installation problem
Replace the hard drive with a new one. IT takes a standard IDE 2.6" laptop drive - I would try newegg.com they have pretty good prices probably about $100 for a 120gb drive.
The hard drive is under the 3x4" cover on the bottomn of the machine.
Dec 31, 2007 | HP Pavilion zd8000 Notebook
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
HP 378248-001 keyboard for Compaq nc6110, nc6120, NX6120 Logo
132 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
