Question about Musicmatch Jukebox 7.0 (1575956454) for PC
Can't open or remove due to mmjb.exe shutdown in unusual way
C:\PROGRA~1\MUSICM~1\MUSICM~2\mmjb.exe shut down in an unusual way
  • 2 more comments
  • connmann68 May 29, 2008
    So do i get my answer even though i don't buy the Premium package?
  • connmann68 May 30, 2008
    Thank you i'll give it a try and see what i come up with
  • LadyElaine1 Jun 23, 2008
    I have the 7.5 free edition of MUSICMATCH Jukebox. I can't open it, or uninstall. If I could at least get it to uninstall I would be so happy.
    Thanks
  • mooneyme Jul 23, 2008
    Lightning storm last night caused the following error window to appear when I try to open my MusicMatch program:
    Program: C:\Program Files\Musicmatch\musicmatch Jukebox\MMJB.EXE
    If I ignore the error window and continue I can hobble through the CD burn, but if I click on the "OK" button or "X" it out, the program shuts down.
    It indicated that I should contact my Musicmatch tech department but WHERE IS THAT???
    Thanks for any help. Mike
    Novelist:
  • 233 Answers
You don't give much information about what your problem is and unfortunately part of what you did write was truncated.
...If I understand your problem you need to uninstall and reinstall, but can't due to a locked file,
I have two suggestions one FREE program is Unlocker Assistant. (Google it) the other is a nice little FREE utility you can try. Install Microsoft "Windows Installer CleanUp Utility" http://support.microsoft.com/kb/290301/en-us
If you find (PROGRAM NAME) listed just hit the delete button.
Then do the normal uninstall.
Posted on May 29, 2008
Slow computer shutdown
Tip #1: Cut down of the programs and processes running in the background.--When you start your computer many unnecessary processes are loaded. You can eliminate this by managing your msconfig.
Here is how:
1. Open your Start menu.
2. Click Run
3. In the command screen type "msconfig.exe"
4. In the system configuration utility,click either service or startup tab.
5. Uncheck all programs that your are no longer want to run in the background.
6. Click OK
Tip #2: Defrag your Computer--The faster your computer can find files the quicker it can shutdown. A very slow computer shutdown can be the result of your hard drive trying to search for disorganized and fragmented files that it needs for shutdown . Organize your hard drive by performing a defragmentation.
Here is how:
1. Open the Start Menu
2. Click on My Computer
3. Right Click your C: drive or your hard drive image.
4. Scroll down to the Properties and Click
5. In the Properties Menus, Open the Tools menu.
6. Choose Defragment Now.
7. In the Disk Deframenter menu. Click on Defragment
Tip #3: Clean your Registry- Usually slow computer shutdown often occurs due to a corrupted registry. You should perform a registry clean, use RegInOut to fix this issue instantly.
Dec 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to Keep Normal Users from Shutting Down a Terminal Server
With Windows 2000 server it is possible for anyone to shutdown the server by default. Sometimes a user, who is not familiar with terminal server can accidentally shutdown a server causing all other users to be disconnected. It is possible to disallow this option from the menu, busying a group policy or other techniques. When using a group policy to remove the shutdown command, it is near impossible to shutdown the server even if
you are the administrator. This method should not be used due to the complexity of shutting down the server after the policy has been enforced. The following method should be used to disallow the shutdown command.
Changing permissions
1. Locate the tsshutdn.exe application; it should be in the c:winntsystem32 folder.
2. Right click the file and select Properties
3. From the Properties windows, click on the Security tab
The following screen appears.
4. Uncheck the box for Allow inheritable permissions from parent to propagate to this object.
This will cause the following warning to appear.
5. Select Copy. This will copy all the current objects.
6. After copying the existing permissions list, remove the Everyone and the Authenticated
Users object.
7. After making this change, click on the Ok button to save the changes and close all open
windows.
With this change made, when a user selects Shutdown from the Start menu the only option
available will be to:
Log off <user>
Disconnect
When the Administrator or a user with admin rights selects Shutdown from the Start menu they will have all
the options available to them:
Shutdown
Restart
Log off <user>
Disconnect
on Apr 18, 2010 | Computers & Internet
Tip
Here's how to create a shutdown shortcut on your desktop
Instead of going to the start menu, choosing shutdown, then waiting for the computer to shut all the programs down, you can create a shortcut on the desktop to do it quickly. You can create a shutdown, restart, or a logoff icon on your desktop which will work a lot quicker than using the usual buttons in the start menu.
1. Go to your blank desktop
2. Right click on a blank space and a menu will appear
3. Choose New from the menu
4. Then choose Shortcut
5. Where it says type the location of the item type in shutdown.exe -s
6. Then press next
7. Now enter a name for your icon. Mine is called SHUTDOWN NOW
8. Press next
9. The Shutdown shortcut will be on your desktop
Different combination you can type in when creating a shortcut to shutdown, restart, or logoff.
Shutdown.exe -s
Shutsdown your computer in 30 seconds and will close all programs and ask you to save all work.
shutdown.exe -r
Restarts your computer in 30 seconds.
shutdown.exe -l
This one will logoff your computer back to the welcome screen where you will need to login again.
shutdown.exe -s -t 1
Shutsdown your computer in one second. the -t 1 tells it how long to wait. (one second in this case) You can put -t 10 or even -t 1120.
shutdown.exe -s -t 15 -c "Goodbye you idiot"
This is my favorite code. It will shutdown in 15 seconds and have a message in the box saying "Goodbye you idiot"
The -c "bla bla bla" stands for a comment.
Notes:
* to stop the computer from shutting down type shutdown /a into the run box located in the start menu..
* -f will force everything to close immediately without asking to save anything.
on Jan 29, 2010 | Computers & Internet
Everytime I turn on my computer, I get this error message: Error loading C:\PROGRA~2\MYWEBS~1\bar'1.bin\F#SCRCTR What does it mean and how can I fix it? My operating system is Microsoft Vista.
Please click on Start, Click on Run and type the following in the open box and click OK
msconfig
Vista: In the Start Search field, type msconfig , and press Enter . The System Configuration window opens.
Or
Press and hold Windows logo key on keyboard and press R. It will open Run Window. Type the following in the open box and click OK
MSconfig
Please click on Startup tab
Remove the check mark from entries related to Mywebsearch OR M3PLUGIN.DLL
Then click on Apply, Close and Please click on Exit without restart.
When the system restarts, you will see a message about System Configuration Utility. Click in the box for "Do not Show this message" and then click on OK.
More on this solution here.
May 05, 2011 | HP Computers & Internet
Windows automatic shutdown
1. create a new text file by opening notepad. 2. paste the following in the text file:
echo off shutdown.exe -r -t 00
3. save the text file but change the .txt file extention to .bat. 4. under control panel, open task scheduler. 5. schedule a new task to run your new .bat file, whenevr the pc should be shut down.
good luck.
Aug 26, 2009 | Computers & Internet
How do i disable m3plugin.dll every time i start up i get the\ message c;\progra-i\mywebs-i\bar3.\bin\m3plugin.dll
it was a virus, luckily your antivirus has already removed it from your pc. one trace is remains in registry which will try to load it on startup.
Ok, do the following step and get rid of it.
Open Run , type regedit and press enter
Go to
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
and check for the key Shell, the value of this must be Explorer.exe . if you can see some other after that like Explorer.exe C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then remove the second file from the value, means it must only Explorer.exe
Ok, then check for the key Userinit. the value must be C:\WINDOWS\system32\userinit.exe, (including the comma) . If after that some thing is there , then delete it.
Ok thats all. restart your system .
Jul 11, 2009 | Intel Motherboard
C\PROGRA~1\MYWEBS`1\bar\.bin\M3PLUGIN.DLL
How to Remove My Web Search.
Download and run,Highjack this from here and save to your desktop
Uninstall the My Web Search option from Add/Remove Programs
1) Click on Start, Settings, Control Panel
2) Double click on Add/Remove Programs
3) Find "My Web Search" in the list of installed programs and click on Change/Remove to uninstall it. You may also want to uninstall any of the following items associated with FunWebProducts.
  • My Web Search (Smiley Central or FWP product as applicable)
  • My Way Speedbar (Smiley Central or other FWP as applicable)
  • My Way Speedbar (AOL and Yahoo Messengers) (beta users only)
  • My Way Speedbar (Outlook, Outlook Express, and IncrediMail)
  • Search Assistant - My Way
4) Reboot your Computer and run HijackThis
5) With HijackThis, scan for and fix any of the entries shown above that may be remaining.
6) Next, open My Computer, Drive C, and double-click on the Program Files folder
7) Right-click and delete the folders for:
  • FunWebProducts
  • MyWebSearch
8) MyWebSearch should now be completely uninstalled from your computer.
9) There will be some minor registry entries left behind by the uninstall, however these can be cleaned up by running SpyBot Search and Destroy or Ad-Aware SE or left alone.
Please rate this a fixya
Jan 31, 2009 | Microsoft Windows XP Home Edition
Dell model DHM DESKTOP which is stuck while plug in .
Try this out:
1. Hold down the Start (Windows Flag Key) button on your keyboard and press R
2. Type this Command : shutdown.exe -s -f -t 00
This will shutdown all running programs and shutdown windows Instantly.
Optionally you can create a desktop shortcut to do this automatically. Here is how:
1. Right click on any blank space of windows desktop -> New -> Shortcut. A “Create Shortcut” window will open.
2. In the blank, type in:
It means, shutdown and wait for Zero second. Click “Next” button for next step.
3. Type in whatever name you like in the blank. I use “Turn Off PC”. Then, click “Finish” button.
4. You are finished . A new shutdown shortcut has been created on your windows desktop!
Just click on it to shutdown.
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
SOLUTION
This is a trace of a virus which remained in the registry will try to load on startup.
1. Open Run , type regedit and press Enter
2. Go to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
and check for the key Shell, the value of this must be Explorer.exe . If you can see some other after that like Explorer.exe C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then remove the second file from the value. It must be only Explorer.exe
3. Then check for the key Userinit. The value must be C:\WINDOWS\system32\userinit.exe, (including the comma) . If after that some thing is there ,delete it.
4. Restart your system .
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
Aug 21, 2008 | Intel Motherboard
Hello i need help?
thank you
bye
Aug 20, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Musicmatch Jukebox 7.0 (1575956454) for PC Logo
227 people viewed this question
Top Musicmatch Computers & Internet Experts
Alun Cox
Bill Boyd
Are you a Musicmatch Computer and Internet Expert? Answer questions, earn points and help others
