Question about Dryers
I need a parts manual . I replaced the belt but it wont heat.
  • 262 Answers
Get your model # and call us 832-695-2102
Posted on Oct 06, 2010
H, I bought a dressmaker 2000 at an estate sale. it runs but the belt won't turn the motor. Ive oiled the machine but it still wont turn the belt looks good any suggestions
Actually, the motor should turn the belt which then runs the machine. Check if the motor is actually turning. If so, then I would suspect either the belt is slipping (needs to be tightened or replaced) or the sewing machine has seized, ie there are moving parts that have frozen and need to be loosened with applications of good quality sewing machine oil (if available, liquid Tri-Flow Synthetic Lube) and heat from a handheld hairdryer.
Jan 28, 2018 | Sewing Machines
Why portable dryer heats but does not spin?
Open it up and check the belt inside. A belt is around the drum and around a pulley at the motor. If it is broken or has slipped off, then it wont spin.
Jan 18, 2016 | Dryers
What is the problem with a 1999 Mercury Sable that is over heating, losing water and the serpentine belt is not turning
belt tensioner is seazed or a pulley is seazed so belt wont turn or belt needs replacement as groves are worn out. the over heating could be your thermostat
Sep 17, 2013 | Mercury Sable Cars & Trucks
Whirlpool duet 2004 model heats but wont spin
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Also check outvideos for other style dryers. If you hear the motor running but it does not tumble it is most likely the belt.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out.
Remove the belt.
Check for obstructions in the blower fan housing.
Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
Oct 21, 2012 | Dryers
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Retractable seat belt wont close
Is this a NEW seat belt?  Or a junkyard part... Per the Toyota 1988 Repair Manual - the belt is allowed to be pulled out at a tile of 15 degrees or less; and cannot be pulled out at over 45 degrees of tilt.
Your problem is the belt is not retracting.  The manual states to replace the assembly.  It also states: "Whenver installing a new belt assembly, verify proper operation before installation."
If a new part does not have proper operation; have it replaced. If this is a 'used'  new part - get a NEW seat belt.
Apr 07, 2009 | 1988 Toyota Camry
Tumble dryer drum wont rotate is it my belt .if so how do i replace it
yes it is the belt,what make and model number(inside dryer door or on it,let me know and we can go from there-mike
Oct 02, 2008 | Dryers
Dryers Logo
Top Dryers Experts
